Datasheets - Клеммные блоки Wago - 3
Подраздел: "Клеммные блоки"
Производитель: "Wago"
Производители
Wago
Найдено: 80 Вывод: 41-60
Вид: Список / Картинки
  1. Datasheet Wago 2273-500
    Mounting carrier; for single- and double-row con.; 2273 Series; for DIN-35 rail mounting/screw mounting
  2. Datasheet Wago 2002-403
    TOPJOB S jumper; for 2002 series; insulated; 3-way; light-gray
  1. Datasheet Wago 281-512/281-501
    Fuse plug with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; with LED indicator; 24 V AC/DC; 6 mm wide
  2. Datasheet Wago 280-621
    4-conductor through terminal block; 2.5 mm²; lateral marker slots; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP
  1. Datasheet Wago 210-133
    Busbar; tin-plated; 1000 mm long; Cu 10 mm x 3 mm
  2. Datasheet Wago 285-195
    2-conductor through terminal block; 95 mm²; lateral marker slots; only for DIN 35 x 15 rail; 2.3 mm thick; copper; POWER CAGE CLAMP
  3. Datasheet Wago 249-117
    Screwless end stop; 10 mm wide
  4. Datasheet Wago 2000-5410/1101-951
    TOPJOB S sensor LED terminal block; yellow LED; for NPN (low side) switching sensors; with ground contact via vertical jumper; 2-pole; rail mount; 4-conductor; 7 mm wide; gray
  5. Datasheet Wago 2006-1631/1099-542
    Fuse disconnect terminal block with pivoting fuse holder and end plate; for miniature metric fuse 1/4" x 11/4"; 30 - 65 V; with blown fuse indication by LED
  6. Datasheet Wago 2007-8801/040-000
    2-conductor through terminal block; 6 mm²; with touch-proof test socket; for 4 mm Ø test plugs; side and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Push-in CAGE CLAMP
  7. Datasheet Wago 2020-5311/1102-950
    3-conductor sensor terminal block; LED (yellow); for PNP-(high-side) switching sensors; with pluggable signal level; 1 mm²; Push-in CAGE CLAMP
  8. Datasheet Wago 2022-1404/999-953
    2-conductor/2-pin carrier terminal block; suitable for Ex nA applications; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP
  9. Datasheet Wago 2102-5307
    TOPJOB S ground terminal block with Lever and Push-buttons; rail mount; 3-conductor; 5.2 mm wide; green-yellow
  10. Datasheet Wago 2106-1204
    TOPJOB S feedthrough terminal block with Lever and Open Tool Slot; rail mount; 2-conductor; 7.5 mm wide; blue
  11. Datasheet Wago 2116-1201
    TOPJOB S feedthrough terminal block with Lever and Open Tool Slot; rail mount; 2-conductor; 10 mm wide; gray
  12. Datasheet Wago 2200-1204
    TOPJOB S feedthrough terminal block with Push-buttons; rail mount; 2-conductor; 3.5 mm wide; blue
  13. Datasheet Wago 2201-1404
    TOPJOB S feedthrough terminal block with Push-buttons; rail mount; 4-conductor; 4.2 mm wide; blue
  14. Datasheet Wago 2204-1404
    TOPJOB S feedthrough terminal block with Push-buttons; rail mount; 4-conductor; 6.2 mm wide; blue
  15. Datasheet Wago 260-420
    2-conductor terminal strip
  16. Datasheet Wago 261-103/331-000
    2-conductor terminal strip; with push-buttons on one side; with fixing flanges; for screw or similar mounting types; Fixing hole 3.2 mm Ø; with 209-123 mounting carrier for DIN 35 rail; 3-pole
