EDN, 17 February, 2011![]() Название: EDN Magazine Издательство: Reed Elsevier Properties Inc. Год выпуска: 2011 Номер: 17 February Число страниц: 60 Формат: PDF Качество: отличное Язык: Английский Размер: 9,9 Mb EDN — это занимающий солидное положение журнал, посвященный электронной промышленности, особенно ее областям, связанным с конструированием и встроенным системам. Cтатьи в нем основаны на добротном материале, хорошо написаны. EDN (Electronic Design News) provides engineers and engineering managers with in-depth design features and deep technical information on microprocessors and other digital ICs, analog ICs, ASICs, computers and software, computer peripherals, test and measurement, components, power sources, interconnections and packaging, and much more. EDN also explores important application areas such as computers, communications, embedded, industrial, and consumer electronics. Designing offline ac/dc switching power supplies, brick by brick It's a challenge to convert high-voltage ac to dc while keeping efficiency high and cost low. Содержание:[spoiler] * Departments and Columns Bakers Best o Photosensing with ambient background Mechatronics In Design o From the real world to the digital world Prying Eyes o The Nexus One: Google hits a smartphone home run Tales From The Cube o A wrench in the works Bakers Best o Generate noisy sine waves with a sound card edn.comment o Stuxnet and the Internet of Victims * Design Ideas Bakers Best o Power supply accepts wide input-voltage range o Reduce acoustic noise from capacitors o Function generator has variable frequency o Circuit lets you test capacitors * Features Design Feature o EDN 2010 Innovation Award finalists: Are you inspired? o Accelerometers and temperature sensors fight SIDS * Pulse o 1-GHz DSP core targets low-cost, high-definition-audio applications o Chip-scale atomic clock survives 500g shock on any axis o Secondary phosphors simplify white-LED-lighting design o Two entry-level scope series mixed-signal capability, built-in waveform generator o CompactPCI single-board computer uses Intel Core processor Voices o Emerging power technology: silicon carbide[/spoiler] Uploading Shareflare |
Телефонные аппараты от А до Я. Книга 2.
АОН в телефонных аппаратах ![]() Автор: С.Л.Корякин-Черняк Издательство: Наука и техника Год:2003 Страниц:288 Формат: pdf Размер: 4.2Мб http://depositfiles.com/files/x3mhh4nqd http://turbobit.net/i1e9n5p0cvdn.html
Последний раз редактировалось MONSTRO; 20.03.2012 в 02:57.
EDN, 3 March, 2011![]() Название: EDN Magazine Издательство: Reed Elsevier Properties Inc. Год выпуска: 2011 Номер: 3 March Число страниц: 56 Формат: PDF Качество: отличное Язык: Английский Размер: 39,9 Mb EDN — это занимающий солидное положение журнал, посвященный электронной промышленности, особенно ее областям, связанным с конструированием и встроенным системам. Cтатьи в нем основаны на добротном материале, хорошо написаны. EDN (Electronic Design News) provides engineers and engineering managers with in-depth design features and deep technical information on microprocessors and other digital ICs, analog ICs, ASICs, computers and software, computer peripherals, test and measurement, components, power sources, interconnections and packaging, and much more. EDN also explores important application areas such as computers, communications, embedded, industrial, and consumer electronics. CPUs in FPGAs: many faces to a trend Whether as synthesizable soft cores or hard cores on the die, CPUs are showing up in more FPGA designs, bringing with them important challenges for designers. Содержание:[spoiler] * Departments and Columns Inside Nanotechnology o New devices for nanoelectronics Signal Integrity o Field cancellation Supply Chain o Counterfeiting continues to grow, but the industry fights back Tales From The Cube o Cheaper to keep'er edn.comment o Windows on ARM: for Intel, probably no cause for alarm * Design Ideas o Design provides single-port-to-dual-port SDRAM converter o Bicolor LED indicates 10 states o Zener diode protects FPGA inputs o Relay driver switches two relays with one pin * Features Design Feature o Build accurate Spice models for low-noise, low-power precision amplifiers o Monitor PWM load current with a high-side current-sense amplifier * Pulse o Generator produces pulses to 330 MHz; functions, noise to 500 MHz o Molybdenite provides advantages over silicon, graphene o High-performance DSP-IP cores are ready for LTE-Advanced o Analog, NI team up on simulation tool o Lighting platform brings building-block approach to LED lighting o Micrel introduces POL buck regulators o Processor touts 3G HSDPA, Android [/spoiler] Uploading Shareflare |
EDN, 17 March, 2011![]() Название: EDN Magazine Издательство: Reed Elsevier Properties Inc. Год выпуска: 2011 Номер: № 6, 17 March Число страниц: 72 Формат: PDF Качество: отличное Язык: Английский Размер: 61,4 Mb EDN — это занимающий солидное положение журнал, посвященный электронной промышленности, особенно ее областям, связанным с конструированием и встроенным системам. Cтатьи в нем основаны на добротном материале, хорошо написаны. EDN (Electronic Design News) provides engineers and engineering managers with in-depth design features and deep technical information on microprocessors and other digital ICs, analog ICs, ASICs, computers and software, computer peripherals, test and measurement, components, power sources, interconnections and packaging, and much more. EDN also explores important application areas such as computers, communications, embedded, industrial, and consumer electronics. Complete IC simulation requires a full toolbox of hardware and software Combining faster solvers with test benches that link analog to digital to system-level models prevents design errors. Содержание: * Departments and Columns Bakers Best o The electrical-overstress ghost Mechatronics In Design o Impedance: an essential multidisciplinary concept Prying Eyes o Remote phosphor expands reach of LED light Tales From The Cube o Acid test edn.comment o Why write about networking ICs? * Design Ideas o Anticipator circuit speeds signal settling to a final value o Schmitt trigger provides toggle function o Active multiplexing saves inputs o Transistor tester identifies terminals o Finely tune the hue of blue-light sources * Features Design Feature o Surpassing the bandwidth limitations of cache-based processing architectures o Hardware choices for MPLS and backbone bridging * Pulse o Dual ARM Cortex-A9 MPCore features 28-nm, low-power programmable logic for high-end embedded systems o Thermal nanotape aims to cool hot spots o System accurately characterizes, tests compliance of PCIe 3.0 receivers o Air hybrid cars could halve fuel consumption o FPGA-reference-design kit eases HDR-video-surveillance-camera development o Midrange scopes feature pivoting displays o Multicore embedded processors accelerate 4G LTE applications Voices o NXP's Rick Clemmer: short-range technology, long-range opportunity Uploading Shareflare |
Название: Словарь технических терминов на 11 языках
Издательство: ACT Автор: коллектив Год: 2004 Страниц: 1104 ISBN: 5-17-021273-9 Качество: хорошее Формат: DjVu Размер: 132 Мб. Язык: 11 языков ![]() Словарь технических терминов на 11 языках: английском, немецком, французском, итальянском, испанском, нидерландском, шведском, польском, чешском, венгерском, русском — содержит около 20 000 слов на каждом из языков и около 200 000 переводов на европейские языки. Словарь содержит полезную терминологию для чтения и перевода технических текстов, для ведения переговоров и деловой переписки. Данное издание создано на основе словаря „Technik in 11 Sprachen", вышедшего в 2001 году в издательстве Compact Verlag. Словарь предназначен для специалистов в области техники, для деловых людей и переводчиков. Скачать с depositfiles.com Скачать с turbobit.net Скачать с letitbit.net
Последний раз редактировалось MONSTRO; 25.05.2012 в 05:01.
Название: Путеводитель по Радио Журналам ( выпуск 2012 года)
Издательство: Терещенко Дмитрий Год: 2012 Язык: Русский Формат: xls (Exel) Качество: отличное Размер: 5Mб ![]() Путеводитель по Радио Журналам ( выпуск 2012 года), в формате MS Excel, представляющая список статей по следующим радио любительским журналам "Радио" 01/1946 по 12/2011 "Радиоаматор" 01/1993 по 12/2011 "Радиоконструктор" 07/1999 по 12/2011 "Радиолюбитель" 01/1991 по 12/2011 "Радиомир" 01/1991 по 10/2011 "Радиомир КВ и УКВ" 01/1998 по 10/2011 "Схемотехника" 01/2000 по 12/2007 "Радиохобби" 01/1999 по 06/2011 "Ремонт&Сервис" 01/1998 по 12/2010 "Ремонт электронной техники" 01/1999 по 04/2008 "Электрик" 01/2000 по 06/2011 "Радиокомпоненты" 01/2006 по 5-6/2009 "Радиосхема" 01/2006 по 04/2011 "В помощь радиолюбителю" 01/1956 по 115/1992 "Альманах в помощь радиолюбителю" 1 по 21 "Мир автоматизации" 01/2005 по 02/2011 "Современная электроника" 01/2004 по 01/2012 "Я электрик" 01/2008 по 03/2011 Всего: 71314 статей Скачать с depositfiles.com Скачать с turbobit.net Скачать с letitbit.net |
Lessons In Electric Circuits. Volume I–DC![]() Название: Lessons In Electric Circuits. Volume I–DC Издательство: Design Science Год выпуска: 2006 Номер: Число страниц: 560 Формат: PDF Качество: отличное Язык: Английский Размер: 4,5 Mb Прекрасный самоучитель по электрическим схемам и основам электроники для начинающих в пяти томах. Том 1 - DC (Все о постоянном токе). Оглавление: Chapter 1: BASIC CONCEPTS OF ELECTRICITY Chapter 2: OHM'S LAW Chapter 3: ELECTRICAL SAFETY Chapter 4: SCIENTIFIC NOTATION AND METRIC PREFIXES Chapter 5: SERIES AND PARALLEL CIRCUITS Chapter 6: DIVIDER CIRCUITS AND KIRCHHOFF'S LAWS Chapter 7: SERIES-PARALLEL COMBINATION CIRCUITS Chapter 8: DC METERING CIRCUITS Chapter 9: ELECTRICAL INSTRUMENTATION SIGNALS Chapter 10: DC NETWORK ANALYSIS Chapter 11: BATTERIES AND POWER SYSTEMS Chapter 12: THE PHYSICS OF CONDUCTORS AND INSULATORS Chapter 13: CAPACITORS Chapter 14: MAGNETISM AND ELECTROMAGNETISM Chapter 15: INDUCTORS Chapter 16: RC AND L/R TIME CONSTANTS Appendix 1: ABOUT THIS BOOK Appendix 2: CONTRIBUTOR LIST Appendix 3: DESIGN SCIENCE LICENSE Uploading Shareflare |
А можно на какой-нибудь другой обменник закинуть?
А то на одном ничего нет, а другой за деньги ... .
http://www.youtube.com/watch?v=aaEkPnf_A1s Отче наш, Отец небесный, я принимаю Веру Твою, она есть мой путь... |
Только что проверил - обе ссылки рабочие. |
Lessons In Electric Circuits. Volume II–AC![]() Название: Lessons In Electric Circuits. Volume II–AC Автор: Tony R.Kuphaldt Издательство: Design Science Год выпуска: 2006 Номер: Число страниц: 570 Формат: PDF Качество: отличное Язык: Английский Размер: 4,6 Mb Прекрасный самоучитель по электрическим схемам и основам электроники для начинающих в пяти томах. Том 2 - AC (Все о переменном токе). Оглавление: Chapter 1: BASIC AC THEORY Chapter 2: COMPLEX NUMBERS Chapter 3: REACTANCE AND IMPEDANCE -- INDUCTIVE Chapter 4: REACTANCE AND IMPEDANCE -- CAPACITIVE Chapter 5: REACTANCE AND IMPEDANCE -- R, L, AND C Chapter 6: RESONANCE Chapter 7: MIXED-FREQUENCY AC SIGNALS Chapter 8: FILTERS Chapter 9: TRANSFORMERS Chapter 10: POLYPHASE AC CIRCUITS Chapter 11: POWER FACTOR Chapter 12: AC METERING CIRCUITS Chapter 13: AC MOTORS Chapter 14: TRANSMISSION LINES Appendix 1: ABOUT THIS BOOK Appendix 2: CONTRIBUTOR LIST Appendix 3: DESIGN SCIENCE LICENSE Скачать Lessons In Electric Circuits. Volume II–AC 2006 PDF: Uploading Shareflare |
