problem in power supply Asus netbook model AD59930
5 1
17.10.2014 22:17 #1
If you put the source into an AC outlet, the source provides the 9.5V but usually put the source in the same netbook and connect the fuse of 1A source burning.
18.10.2014 07:20 #2
Most likely the voltage that you see that testimony voltage for starting the initial unit conversion. Faulty the inverter.
Часовой пояс GMT +3, время: 16:38.
