Product Brochure - Probes and Accessories for Rohde & Schwarz Oscilloscopes (Rohde&Schwarz) - 10
ПроизводительRohde&Schwarz
ОписаниеTest applications for oscilloscopes range from debugging complex electronic circuits to measuring the signal integrity of high-speed bus signals and characterizing power electronics with dangerous voltage levels.
Страниц / Страница32 / 10 — High signal fidelity with active probes. Wide dynamic range with …
Версия13.01
Формат / Размер файлаPDF / 13.3 Мб
High signal fidelity with active probes. Wide dynamic range with additional offset compensation
High signal fidelity with active probes Wide dynamic range with additional offset compensation
Single-ended Single-ended active probes are used to accurately mea- sure ground-referenced signals. They precisely measure both high-speed and low-frequency signals for which it broadband probes is critical that the probe impedance places only a mini- mal load on the test point. Rohde & Schwarz offers a va- riety of models with a maximum bandwidth up to 6 GHz. A particularly wide dynamic range, exceptionally Rohde & Schwarz single-ended active probes feature a high input impedance of 1 MΩ, a low input capacitance down low offset and gain errors and the right accessories to 0.3 pF and noise down to 2 mV (RMS) referenced to the make these probes the ideal accessory for input. Rohde & Schwarz oscilloscopes.
In addition to the wide dynamic range, Rohde & Schwarz single-ended active probes also offer an offset compen- sation. As a result, the DC component of the measured signal can be compensated so that the signal components of interest are displayed on the oscilloscope at maximum resolution. The maximum input voltage of 30 V ensures that the probe is not damaged by overloads. A low-voltage, single-ended probe is typically used for measuring high-speed, ground-referenced signals up to 12 V.
Wide dynamic range: ±8 V, expandable with additional offset compensation of ±12 V (±10 V for R&S®RT-ZS60)
+30 V +20 V Overload Offset +10 V +10 V +8 V Dynamic range Offset range 0 V ±8 V ±10 V –8 V Offset –10 V –10 V –20 V –30 V Practical design: micro button for convenient instrument control. Diverse max. ±30 V nondestructive input voltage probe tips and ground cables are included as standard.
10
Probes_and_accessories_bro_en_3606-8866-12_v1301.indd 10 16.07.2018 16:25:55
