User manual RT-ZF1 USB 2.0 Compliance Test Fixture Set (Rohde&Schwarz) - 6
ПроизводительRohde&Schwarz
ОписаниеRT-ZF1 USB 2.0 Compliance Test Fixture Set Manual
Страниц / Страница19 / 6 — R&S. RT-ZF1. Product Description. 2.1. Deliveries. 2.1.1. Boards. …
Версия06.00
Формат / Размер файлаPDF / 6.7 Мб
R&S. RT-ZF1. Product Description. 2.1. Deliveries. 2.1.1. Boards. Risk of electrostatic discharge
R&S RT-ZF1 Product Description 2.1 Deliveries 2.1.1 Boards Risk of electrostatic discharge
R&S
Deliveries 2 Product Description The R&S RT‑ZF1 USB 2.0 compliance test fixture set is a product for automatic testing of USB 2.0 compliance (high-speed) as well as USB 1.1 (full-speed) and USB 1.0 (low-speed). It is used in combination with the R&S RTO oscilloscopes, with the R&S RTO-K21 USB 2.0 compliance test option (1317.4103.02) and the R&S ScopeSuite software.
2.1 Deliveries
The R&S RT‑ZF1 comprises two test boards and accessories.
2.1.1 Boards
The main components of USB 2.0 compliance test fixture set are two test boards: ● Load board (1317.5300.02) ● Signal quality board (1317.5200.02) The boards are designed for testing USB devices. Make sure to connect only USB interfaces to the boards.
Both boards are sensitive to ESD because they are open modules. Protect the work area against electrostatic discharge to avoid damage to electronic components in the modules. Always work at a static-approved workstation.
EMI impact on measurement results
Electromagnetic interference (EMI) can affect the measurement results. To avoid any impact, use only USB cables shorter 3 m. Manual 1317.4326.02 ─ 06
6
Document Outline Cover Contents 1 Usage Information 2 Product Description 2.1 Deliveries 2.1.1 Boards 2.1.2 Accessories 2.2 Test Equipment 2.3 Specifications 3 Connections and Switches 3.1 Oscilloscope Connections 3.2 Signal Quality Board 3.3 Load Board 4 Preparing the Measurements 4.1 Installing Software and License 4.2 Setting Up the Network 4.3 Starting the R&S ScopeSuite 4.4 Connecting the R&S RTO 4.5 Connecting the Arbitrary Waveform Generator 4.6 Report Configuration
