Клеммники KEEN SIDE
Datasheet HC-SR04 (ElecFreaks) - 2
ПроизводительElecFreaks
ОписаниеUltrasonic ranging module HC-SR04 provides 2cm-400cm non-contact measurement function, the ranging accuracy can reach to 3mm.
Страниц / Страница3 / 2 — Vcc Trig Echo GND. Timing diagram
Формат / Размер файлаPDF / 81 Кб
Vcc Trig Echo GND Timing diagram
The Timing diagram is shown below. You only need to supply a short 10uS pulse to the trigger input to start the ranging, and then the module will send out an 8 cycle burst of ultrasound at 40 kHz and raise its echo. The Echo is a distance object that is pulse width and the range in proportion .You can calculate the range through the time interval between sending trigger signal and receiving echo signal. Formula: uS / 58 = centimeters or uS / 148 =inch; or: the range = high level time * velocity (340M/S) / 2; we suggest to use over 60ms measurement cycle, in order to prevent trigger signal to the echo signal.
