Динамик ВЧ профессиональный Visaton HTH 8.7
Professional CD-Horn (constant directivity) for the highrange above 3000 Hz.
The square shaped horn system is made of rugged black plastic and equipped with a 25 mm voice-coil for high power handling. The horn can therefore be used as an ideal highrange component for compact 2- and 3-way-speakers used as stage monitors or small PA for instruments and vocals.
