Динамик СЧ SEAS H1262-08 (MCA15RCY)
MCA15RCY is a 15 cm (5’’) cone driver, developed for use as a high quality midrange unit.
МосЧип
10H1262по запросу
Датчики давления китайских производителей: высокое качество и доступность
Classically coated paper cone gives a smooth extended frequency response with a controlled roll off. The large magnet system, together with the light cone give high sensitivity with low distortion and good transient response. Extremely stiff and stable injection moulded metal basket keeps the critical components in perfect alignment. Large windows in the basket both above and below the spider reduce sound reflection, air flow noise and cavity resonance to a minimum.
H126208 (MCA15RCY), H1262 08 (MCA15RCY)
