Динамик СЧ/НЧ SEAS H1217-08 (CA18RLY)
6,5” High Fidelity cone driver, developed for use as a high quality woofer or woofer/midrange unit.
Подставка фуршетная P.L. Proff Cuisine набор 3 шт П прямоуг. (14/17/20 см h12/17/21 см) нерж. (81240828) используется для выставления блюд с...
Whitegoods
набор 3 шт П прямоуг. (14/17/20 см h12/17/21 см) нерж. (81240828) - 812408286 473 ₽
Classical coated paper cone gives a smooth extended frequency response with a controlled roll off. High temperature, light weight, CCAW voice coil wound on an aluminium voice coil former gives a high power handling capacity. The extremely stiff and stable injection moulded metal basket, keeps the critical components in
perfect alignment. Large windows in the basket both above and below the spider reduce sound reflection, air flow noise and cavity resonance to a minimum. The large magnet system provides high efficiency and low Q.
H121708 (CA18RLY), H1217 08 (CA18RLY)
