Публикации: tda tda AUDIO amplifier with mute - 8
Поиск по: "tda tda AUDIO amplifier with mute"
Добавлены слова из словаря: "аудио усилитель amp amplfier"
Найдено: 41,639 Вывод: 71-80   В том числе: amplifier (35094); AUDIO (9743); tda (963); mute (266); with (0).
  1. .. Описание: ИС, аудио мощность усилитель, 11 Вт, TO-220 Скачать Data Sheet Краткое содержание документа: LM4752 Stereo 11W Audio Power Amplifier May 14, 2008 LM4752 Stereo 11W Audio Power Amplifier General Description The LM4752 is a stereo ...
    .. external component count offer high value for compact stereo and TV applications. A simple mute function can be implemented with the addition of a few external components. Спецификации: Peak Reflow Compatible (260 C): Yes RoHS: есть
    15 февраля 2011
  2. 8 предложений от 6 поставщиков
    Applicable to Raspberry Pi 3B+ AMP analog power amplifier module with CLASS-D audio power amplifier (supporting acrylic case)
    Триема
    TDA1013B 4W Audio Power Amplifier With Dc Volume Contro
    63 ₽
    AUDIO AMPLIFIER BOARD|X-NUCLEO-CCA01M1
    2 946 ₽
  1. Datasheet LM4766T/NOPB - National Semiconductor Даташит ИС, аудио PWR усилитель CLASS AB 40 Вт TO-220-15
    .. Описание: ИС, аудио PWR усилитель CLASS AB 40 Вт TO-220-15 Скачать Data Sheet Краткое содержание документа: LM4756 Dual 7W Audio Power Amplifier w/Mute, Standby and Volume Control September 2003 LM4756 Dual 7W Audio Power Amplifier w/Mute, ...
    .. The LM4756 is a stereo audio amplifier capable of delivering 7W/channel at 10% distortion into a 4 or 8 load. The power amp has an internally set gain of 30dB. A 0V­5V DC controlled volume block provides 80dB of attenuation from input to ...
    .. functions provide over 75dB of attenuation. The LM4756 maintains an excellent Signal-to-Noise ratio of greater than 70dB with a low noise floor less than 2mV. The IC also maintains above 50dB of channel separation. The LM4756 is available ...
    15 февраля 2011
  1. Datasheet LM4838LQ - National Semiconductor Даташит усилитель, аудио POWER, DC VOLT, LLP-28
    .. Описание: Усилитель, аудио POWER, DC VOLT, LLP-28 Скачать Data Sheet Краткое содержание документа: LM4838 Stereo 2W Audio Power Amplifiers with DC Volume Control and Selectable Gain November 2004 LM4838 Stereo 2W Audio Power ...
    .. computer applications. The LM4838 features an externally controlled, low-power consumption shutdown mode, and both a power amplifier and headphone mute for maximum system flexibility and performance. Спецификации: Количество каналов: 2 ...
    15 февраля 2011
  2. Datasheet LM4838MT - National Semiconductor Даташит усилитель, аудио, стерео 2 Вт, SMD, TSSOP28
    .. Описание: Усилитель, аудио, стерео 2 Вт, SMD, TSSOP28 Скачать Data Sheet Краткое содержание документа: LM4838 Stereo 2W Audio Power Amplifiers with DC Volume Control and Selectable Gain November 2004 LM4838 Stereo 2W Audio Power ...
    15 февраля 2011
  3. Datasheet LM4838MTE - National Semiconductor Даташит усилитель, аудио, стерео 2.2 Вт, SMD, TSSOP28
    .. Описание: Усилитель, аудио, стерео 2.2 Вт, SMD, TSSOP28 Скачать Data Sheet Краткое содержание документа: LM4838 Stereo 2W Audio Power Amplifiers with DC Volume Control and Selectable Gain November 2004 LM4838 Stereo 2W Audio Power ...
    15 февраля 2011
  4. Datasheet LM4839MTE - National Semiconductor Даташит усилитель, аудио, стерео 2.2 Вт, SMD, TSSOP28
    .. Описание: Усилитель, аудио, стерео 2.2 Вт, SMD, TSSOP28 Скачать Data Sheet Краткое содержание документа: LM4839 Stereo 2W Audio Power Amplifiers with DC Volume Control, Bass Boost, and Input Mux April 2002 LM4839 Stereo 2W Audio Power ...
    .. computer applications. The LM4839 features an externally controlled, low-power consumption shutdown mode, and both a power amplifier and headphone mute for maximum system flexi Спецификации: Количество каналов: 2 Количество выводов: 28 ...
    15 февраля 2011
  5. Datasheet LM4755T/NOPB - National Semiconductor Даташит усилитель, POWER, аудио, 2 CH, CLASS AB
    .. Описание: Усилитель, POWER, аудио, 2 CH, CLASS AB Скачать Data Sheet Краткое содержание документа: LM4755 Stereo 11W Audio Power Amplifier with Mute May 2002 LM4755 Stereo 11W Audio Power Amplifier with Mute General Description The ...
    15 февраля 2011
  6. Datasheet SA58632BS - NXP Даташит ИС, усилитель, аудио, 2.2 Вт, STER, 20HVQFN
    .. ИС, усилитель, аудио, 2.2 Вт, STER, 20HVQFN Скачать Data Sheet Краткое содержание документа: SA58632 2 Ч 2.2 W BTL audio amplifier Rev. 02 -- 4 March 2010 Product data sheet 1. General description The SA58632 is a two-channel audio ...
    .. The SA58632 is a two-channel audio amplifier in an HVQFN20 package. It provides power output of 2.2 W per channel with an 8 load at 9 V supply. The internal circuit is comprised of two BTL (Bridge-Tied Load) amplifiers with a ...
    .. circuit is comprised of two BTL (Bridge-Tied Load) amplifiers with a complementary PNP-NPN output stage and standby/mute logic. The SA58632 is housed in a 20-pin HVQFN package, which has an exposed die attach paddle enabling reduced ...
    23 февраля 2011
  7. Datasheet SA58637BS - NXP Даташит Усилитель, аудио, 2.2 Вт, STER, D, 20HVQFN
    .. Описание: Усилитель, аудио, 2.2 Вт, STER, D, 20HVQFN Скачать Data Sheet Краткое содержание документа: SA58637 2 Ч 2.2 W BTL audio amplifier Rev. 01 -- 25 February 2008 Product data sheet 1. General description The SA58637 is a two-channel ...
    .. The SA58637 is a two-channel audio amplifier in an HVQFN20 package. It provides power output of 2.2 W per channel with an 8 load at 9 V supply. The internal circuit is comprised of two Bridge-Tied Load (BTL) amplifiers with a ...
    .. circuit is comprised of two Bridge-Tied Load (BTL) amplifiers with a complementary PNP-NPN output stage and standby/mute logic. The SA58637 is housed in a 20-pin HVQFN package, which has an exposed die attach paddle enabling reduced ...
    23 февраля 2011
  8. Datasheet CS44600-CQZ - Cirrus Logic Даташит Аудио усилитель, DIG CONTR, 192 кГц, 64LQFP
    .. for Single-Ended Mode Eliminates AM Frequency Interference Programmable Load Compensation Filters Support for up to 40 kHz Audio Bandwidth Digital Volume Control with Soft Ramp ­ +24 to -127 dB in 0.25 dB Steps Per Channel Programmable Peak ...
    .. Аудио усилитель, DIG CONTR, 192 кГц, 64LQFP Скачать Data Sheet Краткое содержание документа: CS44600 6-Channel Digital Amplifier Controller Features > 100 dB Dynamic Range - System Level < 0.03% THD+N @ 1 W - System Level 32 kHz to ...
    .. Port and Host Control Port Supplies PS_SYNC XTAL XTI XTO SYS_CLK DAI_MCLK DAI_SCLK DAI_LRCK DAI_SDIN1 DAI_SDIN2 DAI_SDIN3 MUTE SCL/CCLK SDA/CDOUT AD1/CDIN AD0/CS RST INT SPI/I2C Host Control Port Auto Fs Detect DAI Serial Port PWM ...
    12 апреля 2011
Поиск "tda tda AUDIO amplifier with mute" в других поисковых системах: DataSheet.ru
