Datasheet Texas Instruments OPA137N/3K — Даташит
Серия | OPA137 |
Модель | OPA137N/3K |
Недорогие операционные усилители с входом на полевых транзисторах 5-SOT-23 от -40 до 85
Low Cost FET-Input Operational Amplifiers datasheet
PDF, 775 Кб, Файл опубликован: 27 сен 2000
Купить OPA137N/3K на РадиоЛоцман.Цены — от 76 до 434 ₽ 15 предложений от 12 поставщиков OP Amp Single GP ±18V/36V 5Pin SOT-23 T/R | |||
OPA137N/3KE4 Texas Instruments | 76 ₽ | ||
OPA137N/3KE4 Texas Instruments | 121 ₽ | ||
OPA137N/3KE4 Texas Instruments | 133 ₽ | ||
OPA137N/3K Texas Instruments | по запросу |
Pin | 5 |
Package Type | DBV |
Industry STD Term | SOT-23 |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | E37 |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | 1.2 |
Pitch (мм) | .95 |
Max Height (мм) | 1.45 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | FET |
CMRR(Min) | 76 дБ |
CMRR(Typ) | 84 дБ |
GBW(Typ) | 1 МГц |
Input Bias Current(Max) | 100 pA |
Iq per channel(Max) | 0.27 мА |
Iq per channel(Typ) | 0.22 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 15 uV/C |
Output Current(Typ) | 25 мА |
Package Group | SOT-23 |
Package Size: mm2:W x L | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
Rail-to-Rail | In to V+ |
Rating | Catalog |
Slew Rate(Typ) | 3.5 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 4.5 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 45 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 3 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Compensate Transimpedance Amplifiers Intuitively (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved. - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA137 (15)
