Datasheet Texas Instruments TLC5947DAP — Даташит
Серия | TLC5947 |
Модель | TLC5947DAP |
24-канальный 12-битный светодиодный драйвер ШИМ с внутренним генератором 32-HTSSOP от -40 до 85
TLC5947 24-Channel, 12-Bit PWM LED Driver With Internal Oscillator datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 14 янв 2015
Купить TLC5947DAP на РадиоЛоцман.Цены — от 154 до 12 840 ₽ 23 предложений от 16 поставщиков TEXAS INSTRUMENTS TLC5947DAPLed Driver, 24 Outputs, Constant Current, 3V-5.5V in, 30MHz switch, 30V/30mA out, HTSSOP-32 | |||
TLC5947DAP Texas Instruments | 154 ₽ | ||
TLC5947DAP Texas Instruments | 189 ₽ | ||
TLC5947DAP Texas Instruments | от 493 ₽ | ||
TLC5947DAP Texas Instruments | по запросу |
Pin | 32 |
Package Type | DAP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 46 |
Carrier | TUBE |
Маркировка | TLC5947 |
Width (мм) | 6.2 |
Length (мм) | 11 |
Thickness (мм) | 1.15 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Ch to Ch Accuracy(Typ) | 2 +/- % |
Data Transfer Rate(Typ) | 30 МГц |
Package Group | HTSSOP |
Package Size: mm2:W x L | 32HTSSOP: 89 mm2: 8.1 x 11(HTSSOP) PKG |
Rating | Catalog |
Special Features | Internal GS Clock,Thermal Shutdown |
- Hardware Design Considerations for a Wireless LED based Display DesignPDF, 682 Кб, Файл опубликован: 11 июн 2014
Scoreboards have different purposes with various features. Scoreboards are typically used for displaying scores of a game played between two teams. These games can be a timed or an untimed event. The application described in this application report creates a multi-sport scoreboard that is cost efficient, portable, and easy to use. The display values on the scoreboard are transmitted wirelessly.
Серия: TLC5947 (10)
- Semiconductors > Power Management > LED Driver > Signage & Large Display LED Driver
