Datasheet Texas Instruments SN74LVTH273MNSREP — Даташит
Серия | SN74LVTH273-EP |
Модель | SN74LVTH273MNSREP |
Enhanced Product 3.3-V Abt Octal D-Type Flip-Flops With Clear 20-SO -55 to 125
SN74LVTH273-EP datasheet
PDF, 649 Кб, Версия: A, Файл опубликован: 22 май 2006
Купить SN74LVTH273MNSREP на РадиоЛоцман.Цены — от 92 до 383 ₽ 16 предложений от 13 поставщиков Flip Flop 1 Element D-Type 8 Bit Positive Edge 20-SOIC (0.209, 5.30mm Width) | |||
SN74LVTH273MNSREP Texas Instruments | 92 ₽ | ||
SN74LVTH273MNSREP Texas Instruments | 126 ₽ | ||
SN74LVTH273MNSREP Texas Instruments | 141 ₽ | ||
SN74LVTH273MNSREP Texas Instruments | по запросу |
Pin | 20 |
Package Type | NS |
Industry STD Term | SOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | LVTH273EP |
Width (мм) | 5.3 |
Length (мм) | 12.6 |
Thickness (мм) | 1.95 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
3-State Output | No |
Bits | 8 |
F @ Nom Voltage(Max) | 160 Mhz |
ICC @ Nom Voltage(Max) | 5 мА |
Тип входа | TTL |
Output Drive (IOL/IOH)(Max) | 64/-32 мА |
Тип выхода | TTL |
Package Group | SO |
Package Size: mm2:W x L | 20SO: 98 mm2: 7.8 x 12.6(SO) PKG |
Rating | HiRel Enhanced Product |
Technology Family | LVT |
VCC(Max) | 3.6 В |
VCC(Min) | 2.7 В |
tpd @ Nom Voltage(Max) | 4.9 нс |
- LVT Family Characteristics (Rev. A)PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti - LVT-to-LVTH ConversionPDF, 84 Кб, Файл опубликован: 8 дек 1998
Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVTH273-EP (3)
- CLVTH273MNSREPG4 SN74LVTH273MNSREP V62/04674-02YE
- Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
