Datasheet Linear Technology LTC6253 — Даташит
Серия | LTC6253 |
720MHz, 3.5mA Dual Power Efficient Rail-to-Rail I/O Op Amps
Datasheet LTC6252, LTC6253, LTC6254
PDF, 968 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 26
720MHz, 3.5mA Quad Power Efficient Rail-to-Rail I/O Op Amps
Купить LTC6253 на РадиоЛоцман.Цены — от 159 до 1 073 ₽ 32 предложений от 22 поставщиков General Purpose Amplifier 2 Circuit Rail-to-Rail 8-DFN (2x2) | |||
LTC6253IMS#PBF Analog Devices | от 159 ₽ | ||
LTC6253CDC#TRMPBF Analog Devices | 197 ₽ | ||
LTC6253CMS#PBF Linear Technology | 297 ₽ | ||
LTC6253CDC PBF Linear Technology | по запросу |
Parameters / Models | LTC6253CDC#PBF | LTC6253CDC#TRMPBF | LTC6253CDC#TRPBF | LTC6253CMS#PBF | LTC6253CMS#TRPBF | LTC6253CMS8#PBF | LTC6253CMS8#TRPBF | LTC6253CTS8#PBF | LTC6253CTS8#TRMPBF | LTC6253CTS8#TRPBF | LTC6253HMS-7#TRPBF | LTC6253HMS8#PBF | LTC6253HMS8#TRPBF | LTC6253HTS8#PBF | LTC6253HTS8#TRMPBF | LTC6253HTS8#TRPBF | LTC6253IDC#PBF | LTC6253IDC#TRMPBF | LTC6253IDC#TRPBF | LTC6253IMS#PBF | LTC6253IMS#TRPBF | LTC6253IMS-7#TRPBF | LTC6253IMS8#PBF | LTC6253IMS8#TRPBF | LTC6253ITS8#PBF | LTC6253ITS8#TRMPBF | LTC6253ITS8#TRPBF |
Av Min Stable, V/V | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Avol, дБ | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 |
CMRR, дБ | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 |
Cdiff, пФ | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
Количество каналов | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Enoise 1/f Corner, Hz | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 | 8000 |
Enoise Density, нВ/rtГц | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 | 2.75 |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
GBW, МГц | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 | 720 |
Ibias, нА | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
Inoise, пА/rtГц | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Inoise 1/f Corner, Hz | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 |
Ios, мкА | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 | 0.03 |
Iout, мА | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 |
Isupply, мА | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 | 3.3 |
LF Enoise, µVPP | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Over-the-Top | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
PSRR, дБ | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 | 70 |
Rail-to-Rail | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both |
Rail-to-Rail In | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Rail-to-Rail Out | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
SR, В/мс | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 | 280 |
Shutdown | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Single Supply | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Ts (0.1%), нс | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 |
Тип | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB |
Voh (from V+), В | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 | 0.065 |
Vol (from V-), В | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 |
Vos, мВ | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 |
Vos TC, мВ/C | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 |
Vs макс., В | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 |
Vs мин., В | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
LTC6253CDC#PBF | LTC6253CDC#TRMPBF | LTC6253CDC#TRPBF | LTC6253CMS#PBF | LTC6253CMS#TRPBF | LTC6253CMS8#PBF | LTC6253CMS8#TRPBF | LTC6253CTS8#PBF | LTC6253CTS8#TRMPBF | LTC6253CTS8#TRPBF | LTC6253HMS-7#TRPBF | LTC6253HMS8#PBF | LTC6253HMS8#TRPBF | LTC6253HTS8#PBF | LTC6253HTS8#TRMPBF | LTC6253HTS8#TRPBF | LTC6253IDC#PBF | LTC6253IDC#TRMPBF | LTC6253IDC#TRPBF | LTC6253IMS#PBF | LTC6253IMS#TRPBF | LTC6253IMS-7#TRPBF | LTC6253IMS8#PBF | LTC6253IMS8#TRPBF | LTC6253ITS8#PBF | LTC6253ITS8#TRMPBF | LTC6253ITS8#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
LTC6252 LTC6252 LTC6254 LTC6254
Серия: LTC6253 (27)
- LTC6253CDC#PBF LTC6253CDC#TRMPBF LTC6253CDC#TRPBF LTC6253CMS#PBF LTC6253CMS#TRPBF LTC6253CMS8#PBF LTC6253CMS8#TRPBF LTC6253CTS8#PBF LTC6253CTS8#TRMPBF LTC6253CTS8#TRPBF LTC6253HMS-7#TRPBF LTC6253HMS8#PBF LTC6253HMS8#TRPBF LTC6253HTS8#PBF LTC6253HTS8#TRMPBF LTC6253HTS8#TRPBF LTC6253IDC#PBF LTC6253IDC#TRMPBF LTC6253IDC#TRPBF LTC6253IMS#PBF LTC6253IMS#TRPBF LTC6253IMS-7#TRPBF LTC6253IMS8#PBF LTC6253IMS8#TRPBF LTC6253ITS8#PBF LTC6253ITS8#TRMPBF LTC6253ITS8#TRPBF
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Speed Amplifiers (GBW > 50MHz) | Low Noise Amplifiers ( | Rail-to-Rail Amplifiers
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Amplifiers
