Datasheet Linear Technology LTC3838-2 — Даташит
СерияLTC3838-2
Dual, Fast, Accurate Step-Down DC/DC Controller with External Reference Voltage and Dual Differential Output Sensing
Datasheet LTC3838-2
PDF, 968 Кб, Язык: анг., Файл закачен: 23 сен 2017, Страниц: 56
LTC3838-2: 4.5-14Vin 1.5Vout1@20A 1.2Vout2@20A
LTC3838EUHF-2#PBFLTC3838EUHF-2#TRPBFLTC3838IUHF-2#PBFLTC3838IUHF-2#TRPBF
N1234
Корпус5x7 QFN-38
Габаритный чертеж корпуса
5x7 QFN-38
5x7 QFN-38
5x7 QFN-38
Код корпусаUHFUHFUHFUHF
Индекс корпуса05-08-170105-08-170105-08-170105-08-1701
Количество выводов38383838
Parameters / ModelsLTC3838EUHF-2#PBFLTC3838EUHF-2#TRPBFLTC3838IUHF-2#PBFLTC3838IUHF-2#TRPBF
АрхитектураControlled On-Time Valley Current ModeControlled On-Time Valley Current ModeControlled On-Time Valley Current ModeControlled On-Time Valley Current Mode
Demo BoardsDC1997A-BDC1997A-BDC1997A-BDC1997A-B
Design ToolsLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD ModelLTspice File,LTpowerCAD Model
Экспортный контрольнетнетнетнет
Основные особенностиDifferential Remote Sense, External Synchronization, Resistor Set Frequency, DCR Current Sense, Power Good, TrackingDifferential Remote Sense, External Synchronization, Resistor Set Frequency, DCR Current Sense, Power Good, TrackingDifferential Remote Sense, External Synchronization, Resistor Set Frequency, DCR Current Sense, Power Good, TrackingDifferential Remote Sense, External Synchronization, Resistor Set Frequency, DCR Current Sense, Power Good, Tracking
Тактовая частота, kHz2000200020002000
Frequency Adjust Range200kHz to 2MHz200kHz to 2MHz200kHz to 2MHz200kHz to 2MHz
Frequency Sync Range200kHz to 2MHz200kHz to 2MHz200kHz to 2MHz200kHz to 2MHz
Integrated Inductorнетнетнетнет
Ishutdown, мкА15151515
Isupply, мА3333
Max Phases2222
Monolithicнетнетнетнет
Количество выходов2222
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 85от -40 до 85
Выходной ток, A30303030
Output Current 2, A30303030
Polyphaseдададада
Sense ResistorRsense, DCRRsense, DCRRsense, DCRRsense, DCR
Switch Current, A30303030
Switch Current 2, A30303030
Synchronousдададада
TopologyBuckBuckBuckBuck
Topology 1BuckBuckBuckBuck
Topology 2BuckBuckBuckBuck
Vin Max, В38383838
Vin Min, В4.54.54.54.5
Vout Max, В5.55.55.55.5
Vout Maximum5.5V5.5V5.5V5.5V
Vout Min, В0.60.60.60.6
Vout Min 2, В0.60.60.60.6
Vref Accuracy Over Temp, %0.670.670.670.67
RoHSСовместимСовместимСовместимСовместим
  • Modeling and Loop Compensation Design of Switching Mode Power Supplies &mdash AN149
    PDF, 1.4 Мб, Файл опубликован: 23 мар 2015
Статьи
  • Dual, Fast, Step-Down Controller's External Reference Input Enables Dynamic Voltage Scaling from 0.4V to 5.5V and 0.3% Total Combined Regulation Accuracy &mdash LT Journal
    PDF, 2.8 Мб, Файл опубликован: 10 апр 2013
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | External Power Switch Buck Controllers
На английском языке: Datasheet Linear Technology LTC3838-2
