Datasheet Linear Technology LTM4630-1 — Даташит
СерияLTM4630-1
Dual 18A or Single 36A µModule (Power Module) Regulator with 0.8% DC and 3% Transient Accuracy
Datasheet LTM4630-1
PDF, 1.3 Мб, Язык: анг., Файл закачен: 25 сен 2017, Страниц: 38
Dual 18A or Single 36A μModule (Power Module) Regulator with 0.8% DC and 3% Transient Accuracy
LTM4630-1: 4.5-15Vin 1.0Vout@36A
LTM4630EY-1A#PBFLTM4630EY-1B#PBFLTM4630IY-1ALTM4630IY-1A#PBFLTM4630IY-1BLTM4630IY-1B#PBF
N123456
Корпус16mm x 16mm x 5.01mm BGA
Габаритный чертеж корпуса
Код корпусаBGABGABGABGABGABGA
Индекс корпуса05-08-196905-08-196905-08-196905-08-196905-08-196905-08-1969
Количество выводов144144144144144144
Parameters / ModelsLTM4630EY-1A#PBFLTM4630EY-1B#PBFLTM4630IY-1ALTM4630IY-1A#PBFLTM4630IY-1BLTM4630IY-1B#PBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC2081A-B,DC2157A,DC2268A-E,DC2164A-A,DC2164A-B,DC2164A-CDC2081A-B,DC2157A,DC2268A-E,DC2164A-A,DC2164A-B,DC2164A-CDC2081A-B,DC2157A,DC2268A-E,DC2164A-A,DC2164A-B,DC2164A-CDC2081A-B,DC2157A,DC2268A-E,DC2164A-A,DC2164A-B,DC2164A-CDC2081A-B,DC2157A,DC2268A-E,DC2164A-A,DC2164A-B,DC2164A-CDC2081A-B,DC2157A,DC2268A-E,DC2164A-A,DC2164A-B,DC2164A-C
Design ToolsLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD File
Экспортный контрольнетнетнетнетнетнет
Основные особенностиDifferential Remote Sense, Resistor Set Frequency, PolyPhase, External Synchronization, Temperature Monitor, Burst Mode, Tracking, Power GoodDifferential Remote Sense, Resistor Set Frequency, PolyPhase, External Synchronization, Temperature Monitor, Burst Mode, Tracking, Power GoodDifferential Remote Sense, Resistor Set Frequency, PolyPhase, External Synchronization, Temperature Monitor, Burst Mode, Tracking, Power GoodDifferential Remote Sense, Resistor Set Frequency, PolyPhase, External Synchronization, Temperature Monitor, Burst Mode, Tracking, Power GoodDifferential Remote Sense, Resistor Set Frequency, PolyPhase, External Synchronization, Temperature Monitor, Burst Mode, Tracking, Power GoodDifferential Remote Sense, Resistor Set Frequency, PolyPhase, External Synchronization, Temperature Monitor, Burst Mode, Tracking, Power Good
Тактовая частота, kHz500500500500500500
Frequency Adjust Range400kHz to 780kHz400kHz to 780kHz400kHz to 780kHz400kHz to 780kHz400kHz to 780kHz400kHz to 780kHz
Frequency Sync Range400kHz to 780kHz400kHz to 780kHz400kHz to 780kHz400kHz to 780kHz400kHz to 780kHz400kHz to 780kHz
Integrated Inductorдададададада
Ishutdown, мкА505050505050
Isupply, мА333333
Max Phases888888
Monolithicдададададада
Количество выходов222222
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A181818181818
Output Current 2, A181818181818
Polyphaseдададададада
Switch Current, A252525252525
Switch Current 2, A252525252525
Synchronousдададададада
TopologyBuckBuckBuckBuckBuckBuck
Topology 1BuckBuckBuckBuckBuckBuck
Topology 2BuckBuckBuckBuckBuckBuck
Vin Max, В151515151515
Vin Min, В4.54.54.54.54.54.5
Vout Max, В1.81.81.81.81.81.8
Vout Max 2, В1.81.81.81.81.81.8
Vout Maximum1.8V1.8V1.8V1.8V1.8V1.8V
Vout Min, В0.60.60.60.60.60.6
Vout Min 2, В0.60.60.60.60.60.6
Vref Accuracy Over Temp, %0.80.80.80.80.80.8
RoHSСовместимСовместимНе совместимСовместимНе совместимСовместим
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck
  • µModule Solutions > µModule Regulators > µModule Buck Regulators
На английском языке: Datasheet Linear Technology LTM4630-1
