Datasheet Linear Technology LTC3545-1 — Даташит
СерияLTC3545-1
Triple 800mA Synchronous Step-Down Regulator - 2.25MHz
Datasheet LTC3545, LTC3545-1
PDF, 305 Кб, Язык: анг., Файл закачен: 21 сен 2017, Страниц: 20
LTC3545-1: 2.25-5.5Vin 1.2/1.5/1.8Vout@800mA
LTC3545EUD-1#PBFLTC3545EUD-1#TRPBFLTC3545IUD-1#PBFLTC3545IUD-1#TRPBF
N1234
Корпус3x3 QFN-16
Габаритный чертеж корпуса
3x3 QFN-16
3x3 QFN-16
3x3 QFN-16
Код корпусаUDUDUDUD
Индекс корпуса05-08-170005-08-170005-08-170005-08-1700
Количество выводов16161616
Parameters / ModelsLTC3545EUD-1#PBFLTC3545EUD-1#TRPBFLTC3545IUD-1#PBFLTC3545IUD-1#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC1193A-A,DC1193A-BDC1193A-A,DC1193A-BDC1193A-A,DC1193A-BDC1193A-A,DC1193A-B
Design ToolsLTspice FileLTspice FileLTspice FileLTspice File
Экспортный контрольнетнетнетнет
Основные особенностиBurst Mode, External Synchronization, Power Good, 100% Duty CycleBurst Mode, External Synchronization, Power Good, 100% Duty CycleBurst Mode, External Synchronization, Power Good, 100% Duty CycleBurst Mode, External Synchronization, Power Good, 100% Duty Cycle
Тактовая частота, kHz2250225022502250
Frequency Sync Range1MHz - 3MHz1MHz - 3MHz1MHz - 3MHz1MHz - 3MHz
Integrated Inductorнетнетнетнет
Ishutdown, мкА0.10.10.10.1
Isupply, мА0.0580.0580.0580.058
Max Phases1111
Monolithicдададада
Количество выходов3333
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 85от -40 до 85
Выходной ток, A0.80.80.80.8
Output Current 2, A0.80.80.80.8
Output Current 3, A.8.8.8.8
Polyphaseнетнетнетнет
Switch Current, A1.31.31.31.3
Switch Current 2, A1.31.31.31.3
Switch Current 3, A1.31.31.31.3
Synchronousдададада
TopologyBuckBuckBuckBuck
Topology 1BuckBuckBuckBuck
Topology 2BuckBuckBuckBuck
Topology 3BuckBuckBuckBuck
Vin Max, В5.55.55.55.5
Vin Min, В2.252.252.252.25
Vout Max, В5.55.55.55.5
Vout Max 2, В5.55.55.55.5
Vout Max 3, В5.55.55.55.5
Vout MaximumVinVinVinVin
Vout Min, В0.60.60.60.6
Vout Min 2, В0.60.60.60.6
Vout Min 3, В0.60.60.60.6
Vref Accuracy Over Temp, %2222
RoHSСовместимСовместимСовместимСовместим
LTC3545 LTC3545
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck | Multiple Output Buck | Micropower Buck Regulators
На английском языке: Datasheet Linear Technology LTC3545-1
