Datasheet AD9601 (Analog Devices) - 8 Производитель Analog Devices Описание 10-Bit, 200 MSPS/250 MSPS 1.8 V Analog-to-Digital Converter Страниц / Страница 33 / 8 — AD9601. TIMING DIAGRAMS. N + 2. N + 1. N + 3. N + 4. N + 8. N + 5. N + 6. … Формат / Размер файла PDF / 989 Кб Язык документа английский
AD9601. TIMING DIAGRAMS. N + 2. N + 1. N + 3. N + 4. N + 8. N + 5. N + 6. N + 7. tCLK = 1/fCLK. CLK+. CLK–. tCPD. DCO–. DCO+. tSKEW. tPD. DAX. N – 7. N – 6
Скачать PDF
Модельный ряд для этого даташита Текстовая версия документа AD9601 TIMING DIAGRAMS N + 2 N + 1 N + 3 N N + 4 N + 8 tA N + 5 N + 6 N + 7 tCLK = 1/fCLK CLK+ CLK– tCPD DCO– DCO+ tSKEW tPD 2 04DAX N – 7 N – 6 N – 5 N – 4 N – 3 N – 2 N – 1 N N + 1 N + 2 0-7100 Figure 2. Single Port ModeN + 2 N + 1 N + 3 N N + 4 N + 8 tA N + 5 N + 7 N + 6 tCLK = 1/fCLK CLK+ CLK– tCPDA tCPDB DCO+ DCO– tSKEWA tPDA DAX N – 6 N – 4 N – 2 N N + 2 tSKEWB tPDB 3 -04DBX N – 7 N – 5 N – 3 N – 1 N + 1 00 071 Figure 3. Interleaved Mode Rev. 0 | Page 7 of 32 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ANALOG INPUT AND VOLTAGE REFERENCE Differential Input Configurations CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Clock Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS Digital Outputs and Timing Out-of-Range TIMING—SINGLE PORT MODE TIMING—INTERLEAVED MODE fS/2 Spurious LAYOUT CONSIDERATIONS POWER AND GROUND RECOMMENDATIONS Exposed Paddle Thermal Heat Slug Recommendations CML RBIAS AD9601 CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI MEMORY MAP READING THE MEMORY MAP TABLE RESERVED LOCATIONS DEFAULT VALUES LOGIC LEVELS EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
