Datasheets Nexperia - 4
Производитель: "Nexperia"
Найдено: 100 Вывод: 61-80
Вид: Список / Картинки
  1. Datasheet Nexperia MMBZ12VAL,215
    Низкоемкостный однонаправленный двойной защитный диод ESD
  2. Datasheet Nexperia MMBZ10VAL,215
  1. Datasheet Nexperia PHK12NQ03LT,518
    N-channel TrenchMOS logic level FET
  2. Datasheet Nexperia BSP122,115
    N-channel vertical D-MOS logic level FET
  1. Datasheet Nexperia PESD2V8R1BSFYL
    Ultra low capacitance bidirectional ESD protection diode Ultra low capacitance bidirectional ElectroStatic Discharge (ESD) protection diode, part of the TrEOS Protection family. This device is housed in a DSN0603-2 (SOD962-2) leadless ultra small ...
  2. Datasheet Nexperia BC817DPN,115
  3. Datasheet Nexperia PCMF3USB3BA/CZ
    Common-mode EMI filter for differential channels with integrated bidirectional ESD protection Common-mode ElectroMagnetic Interference (EMI) filters with integrated bidirectional ElectroStatic Discharge (ESD) protection for one, two and three ...
  4. Datasheet Nexperia PCMF2USB3BA/CZ
  5. Datasheet Nexperia PCMF1USB3BA/CZ
  6. Datasheet Nexperia GAN063-650WSAQ
    650 V, 50 mΩ Gallium Nitride (GaN) FET The GAN063-650WSA is a 650 V, 50 mΩ Gallium Nitride (GaN) FET. It is a normally-off device that combines Nexperia’s state-of-the-art high-voltage GaN HEMT and low-voltage silicon MOSFET technologies — offering ...
  7. Datasheet Nexperia BCV61C,215
    NPN general-purpose double transistors NPN general-purpose double transistors in a small SOT143B Surface-Mounted Device (SMD) plastic package.
  8. Datasheet Nexperia BCV61B,215
  9. Datasheet Nexperia BCV61A,215
  10. Datasheet Nexperia BCV61,235
  11. NPN/PNP general-purpose transistor pair in a very small SOT363 (SC-88) Surface-Mounted Device (SMD) plastic package.
  12. Voltage regulator diodes
  13. PNP switching transistor in a SOT23 plastic package. NPN complement: MMBT3904.
  14. Automotive qualified logic level N-channel MOSFET in an LFPAK33 package using Trench 9 TrenchMOS technology. This product has been designed and qualified to AEC-Q101 for use in high performance automotive applications.
  15. Automotive qualified standard level N-channel MOSFET in an LFPAK33 package using Trench 9 TrenchMOS technology. This product has been designed and qualified to AEC-Q101 for use in high performance automotive applications.
  16. PNP high-voltage transistor in a SOT23 plastic package.
