.. for easy identification · 4 main pole versions available introducing the 3-pole contactors Standard coil voltages 24V 50/60Hz, 110V 50/60Hz 220-240V 50Hz, 380-415V 50Hz 24V DC AC operated actual size Спецификации: Load Current Inductive: ...
.. Rating: 6 А Dielectric Voltage Coil to Contact: 300 В AC Dielectric Voltage Contact to Contact: 300 В AC Frequency Max: 60Hz Frequency Min: 50Hz IP / NEMA Rating: IP20 Insulation Voltage: 690 В AC Terminal Type: Screw Terminals
.. of Poles: 3 Series: DILEM Approval Bodies: IEC/EN 60947, VDE0660, CSA, UL Aux Contact Current Max: 10 А Coil Frequency Max: 60Hz Coil Operating Frequency Min: 50Hz Coil Voltage Max: 240 В Coil Voltage Min: 220 В Dielectric Voltage Coil to ...
.. Coil to Contact: 400 В AC Dielectric Voltage Contact to Contact: 400 В AC IP Rating: 20 Max Coil Operating Frequency: 60Hz Max Coil Voltage: 240 В AC Max Main Contact Current AC1: 20 А Max Main Contact Current AC3: 9 А Min Coil ...
.. 400 В Mounting Type: DIN Rail / Panel No. of Poles: 3 Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA Coil Frequency Max: 60Hz Dielectric Voltage Coil to Contact: 440 В AC Dielectric Voltage Contact to Contact: 440 В AC IP / NEMA Rating: 00 ...
.. Operating Temperature Max: 60°C Series: 3RH11 Temperature Operating Min: -25°C Approval Bodies: UL, CSA Coil Frequency Max: 60Hz Coil Operating Frequency Min: 50Hz Dielectric Strength VAC: 600 В AC IP / NEMA Rating: 20 Main Contact Current ...
.. Coil to Contact: 400 В AC Dielectric Voltage Contact to Contact: 400 В AC IP Rating: 20 Max Coil Operating Frequency: 60Hz Max Coil Voltage: 120 В AC Max Main Contact Current AC1: 20 А Max Main Contact Current AC3: 9 А Min Coil ...
.. 400 В Mounting Type: DIN Rail / Panel No. of Poles: 3 Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA Coil Frequency Max: 60Hz Dielectric Voltage Coil to Contact: 400 В AC Dielectric Voltage Contact to Contact: 400 В AC IP / NEMA Rating: 20 ...
.. Rating: 6 А Dielectric Voltage Coil to Contact: 400 В AC Dielectric Voltage Contact to Contact: 400 В AC Frequency Max: 60Hz Frequency Min: 50Hz IP / NEMA Rating: IP20 Input Voltage Max: 240 В AC Input Voltage Min: 230 В AC Terminal Type: ...
