Datasheet ТI LM5022MM — Даташит
| Серия | LM5022 |
| Модель | LM5022MM |
Широкий диапазон напряжения 6–60 В, режим повышения тока и контроллер SEPIC 10-VSSOP от -40 до 125
LM5022 60-V Low-Side Controller for Boost and SEPIC datasheet
PDF, 1.5 Мб, Версия: H, Файл опубликован: 16 дек 2016
- Driving LEDs: To Cap or Not to CapPDF, 542 Кб, Файл опубликован: 21 мар 2007
- AN-1696 Designing a Boost LED Driver Using the LM5022 (Rev. B)PDF, 238 Кб, Версия: B, Файл опубликован: 6 май 2013
This application report provides a component-by-component design guide for a boost converter-basedLED driver using the LM5022. - Demystifying Type II and Type III Compensators Using Op-Amp and OTA for DC/DC CoPDF, 782 Кб, Файл опубликован: 11 июл 2014
- AN-1656 Design Challenges of Switching LED Drivers (Rev. A)PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM5022 (4)
- LM5022MM LM5022MM/NOPB LM5022MME/NOPB LM5022MMX/NOPB
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Controller (External Switch)
