Datasheet ТI LM5121MHE/NOPB — Даташит
| Серия | LM5121 |
| Модель | LM5121MHE/NOPB |
Широкий диапазон напряжения 3–65 В, синхронное усиление в режиме тока с управлением выключателем-разъединителем 20-HTSSOP от -40 до 125
LM5121/-Q1 Wide Input Synchronous Boost Controller with Disconnection Switch Control datasheet
PDF, 3.0 Мб, Версия: C, Файл опубликован: 14 июн 2016
- Automated Frequency Response AnalyzerPDF, 939 Кб, Файл опубликован: 9 окт 2013
This application report discusses a new method of doing stability Analysis testing by using basic labequipment, while not requiring any specific instruments. - Designing the front-end DC/DC conversion stage to withstand automotive transientPDF, 336 Кб, Файл опубликован: 18 янв 2017
- Practical Feedback Loop Analysis for Current-Mode Boost ConverterPDF, 557 Кб, Файл опубликован: 7 мар 2014
- Designing Fault Protection Circuits Using Wide VIN LM5121PDF, 186 Кб, Файл опубликован: 12 янв 2015
Battery powered systems or systems with low input voltage supplies may have loads that require higher voltage outputs. A boost converter is a usual choice for non-isolated applications; however, boost converters do not naturally provide system protection to downstream circuitry due to the pass path from input to output. Problems due to this pass path are now resolved with the LM5121 boost controll
Серия: LM5121 (3)
- LM5121MH/NOPB LM5121MHE/NOPB LM5121MHX/NOPB
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Controller (External Switch)
