Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI TMS320DM8168SCYGA2 — Даташит
СерияTMS320DM8168
МодельTMS320DM8168SCYGA2
Datasheet Texas Instruments TMS320DM8168SCYGA2
Цифровой медиапроцессор DaVinci 1031-FCBGA от -40 до 105
TMS320DM816x DaVinci Digital Media Processors datasheet
PDF, 2.6 Мб, Версия: F, Файл опубликован: 17 мар 2015
  • DM816x, C6A816x, and AM389x Overview
    PDF, 29 Кб, Файл опубликован: 7 июл 2011
    This article provides an overview of the DM816x, C6A816x, and AM389x product families and has been contributed to the TI Embedded Processors Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/DM816x_C6A816x_AM389x_OverviewAll t
  • TMS320DM816x/C6A816x/AM389x DDR3 Initialization With Software Leveling
    PDF, 21 Кб, Файл опубликован: 1 мар 2011
    This article has been contributed to the TI Embedded Processors Wiki. The article describes how to initialize the DDR3 on the TMS320DM816x DaVinciв„ў digital media processors, TMS320C6A816x Integraв„ў DSP+ ARMВ® processors, and AM389x Sitaraв„ў ARMВ® microprocessors (MPUs) PG1.1 samples using the software leveling process.To see the most recently updated version or to cont
  • PCIe to USB on the TMS320DM816x/TMS320C6A816x/AM389x Evaluation Board
    PDF, 22 Кб, Файл опубликован: 1 мар 2011
    This article has been contributed to the TI Embedded Processors Wiki. The article describes using the PCI ExpressВ® ( PCIeВ®) to the USB host controller card on the TMS320DM816x DaVinciв„ў digital media processors, TMS320C6A816x Integraв„ў DSP+ ARMВ® processors, and AM389x Sitaraв„ў ARMВ® microprocessors (MPUs) family of devices running Linux kernel from a PSP package. This
  • TMS320DM816x/TMS320C6A816x/AM389x Power Estimation Spreadsheet
    PDF, 30 Кб, Файл опубликован: 18 май 2011
    This article has been contributed to the TI Embedded Processors Wiki. It describes how to model power consumption for a user's application and to present some measured power scenarios for the TMS320DM816x DaVinciв„ў digital media processors, TMS320C6A816x C6-Integraв„ў DSP+ARM processors, and AM389x Sitaraв„ў ARMВ® microprocessors (MPUs) PG1.0 samples using a provided power estimati
  • DM816xx Easy CYG Package PCB Escape Routing (Rev. A)
    PDF, 675 Кб, Версия: A, Файл опубликован: 19 мар 2015
    The DM816x CYG package is designed with a new technology called a Via Channelв„ў array. This technology allows for easy routing of the device in two signal and two power layers using large throughhole via diameters and standard trace widths; it is cost and time effective. Where more than four printed circuit board (PCB) layers are used, the routing is much more open and flexible than a regular
  • Canny Edge Detection Implementation on TMS320C64x/64x+ Using VLIB
    PDF, 97 Кб, Файл опубликован: 25 ноя 2009
    This application note contains instructions for implementing Canny Edge Detection algorithm using VLIB. The general ideas given here can also be applied for an application which calls a sequence of VLIB functions in a block-based manner.
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Digital Signal Processors > Media Processors > Digital Video Processors
На английском языке: Datasheet Texas Instruments TMS320DM8168SCYGA2
Политика конфиденциальности
