Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI TPS79333DBVRG4 — Даташит
СерияTPS793
МодельTPS79333DBVRG4
Datasheet Texas Instruments TPS79333DBVRG4
Высокий PSRR, низкий уровень шума, LDO с одним выходом, 200 мА, 5-SOT-23 от -40 до 125
TPS793 Low-Noise, High PSRR, RF, 200-mA Low-Dropout Linear Regulators in NanoStarв„ў Wafer Chip Scale and SOT-23 datasheet
PDF, 1.2 Мб, Версия: L, Файл опубликован: 7 авг 2014
  • NanoStarв„ў Wafer Chip-Scale Package Design Guide
    PDF, 286 Кб, Файл опубликован: 5 сен 2003
    To satisfy market demand for an ultra-small, staggered 5-ball wafer-level chip-scale package, TI has introduced the 170Ојm NanoStar YEQ package. Since staggered ball WCSPs are not registered under the JEDEC MO-211 standard, there are no formal industry-standard guidelines on proper use of devices in this package. This application note gives guidelines for reliable, high-performance use of the YE
  • NanoStarв„ў & NanoFreeв„ў 300Ојm Solder Bump WCSP Application
    PDF, 749 Кб, Файл опубликован: 2 фев 2004
    The NanoStarв„ў Wafer Chip-Scale Package (WCSP) is a family of bare die packages developed for applications that require the smallest possible package. WCSP provides electrical interconnection via solder spheres attached to the die and is aligned with JEDEC package standard MOв€’211. NanoStarв„ў, with advanced materials engineering technology, has demonstrated excellent board level rel
  • Cycloneв„ў III FPGA Starter Kit Power Reference Design
    PDF, 314 Кб, Файл опубликован: 27 мар 2008
    This power supply was designed to power the 3C25F324 starter kit. This reference design has many benefits over the existing power supply found on the starter kit demonstration board.
На английском языке: Datasheet Texas Instruments TPS79333DBVRG4
Политика конфиденциальности
