Заказные клавиатуры Accord по вашему ТЗ
Datasheet ТI PCF8574DWE4 — Даташит
СерияPCF8574
МодельPCF8574DWE4
Datasheet Texas Instruments PCF8574DWE4
Удаленный 8-битный расширитель ввода-вывода для шины I2C 16-SOIC от -40 до 85
PCF8574 Remote 8-Bit I/O Expander for I2C Bus datasheet
PDF, 1.6 Мб, Версия: J, Файл опубликован: 9 мар 2016
  • Improving System Interrupt Management Using the PCF8574 and PCF8574A I/O Expande
    PDF, 216 Кб, Файл опубликован: 27 июл 2001
    In today?s complex, embedded, computing and data-communication systems, interrupts areused extensively to service peripheral devices. However, because of the pin-numberlimitation on packages, most microprocessors have only one or two interrupt lines.Consequently, several devices usually are connected to the same interrupt line. Thedrawback to this configuration is that the overhead process
  • Programming Fun Lights With TI's TCA6507
    PDF, 109 Кб, Файл опубликован: 30 ноя 2007
  • Choosing the Correct I2C Device for New Designs
    PDF, 87 Кб, Файл опубликован: 7 сен 2016
    The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h
  • Maximum Clock Frequency of I2C Bus Using Repeaters
    PDF, 116 Кб, Файл опубликован: 15 май 2015
    TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters
  • I2C Bus Pull-Up Resistor Calculation
    PDF, 157 Кб, Файл опубликован: 13 фев 2015
  • Understanding the I2C Bus
    PDF, 124 Кб, Файл опубликован: 30 июн 2015
  • Semiconductors > Interface > I2C > I2C General Purpose I/O (GPIO)
На английском языке: Datasheet Texas Instruments PCF8574DWE4
Политика конфиденциальности
