Datasheet Texas Instruments TPA3131D2RHBR — Даташит
СерияTPA3131D2
МодельTPA3131D2RHBR
Стереоусилитель класса D без фильтров мощностью 7 Вт, экономящий место QFN 32-VQFN от -40 до 85
TPA313xD2 4-W, 25-W Filter-Free Class-D Stereo Amplifier With AM Avoidance datasheet
PDF, 1.8 Мб, Версия: B, Файл опубликован: 16 янв 2015
Pin32
Package TypeRHB
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаTPA3131
Width (мм)5
Length (мм)5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Analog Supply (V)26 Min
АрхитектураClass D
Control InterfaceHardware
Iq per channel(Typ)16 мА
Iq(Typ)16 мА
Load(Min)2 ohms
Выходная мощность25 W
PSRR70 дБ
Package GroupVQFN
Package Size: mm2:W x L32VQFN: 25 mm2: 5 x 5(VQFN) PKG
Pin/Package32VQFN
Shutdown Current (ISD)50 uA
Speaker ChannelsStereo Max
THD + N @ 1 kHz0.1 %
  • Evaluation Modules & Boards: TPA3131D2EVM
    TPA3131D2EVM for 7W Class-D Speaker Amplifier
  • Layout Guidelines For TPA300x Series Parts
    PDF, 647 Кб, Файл опубликован: 15 июл 2003
    This article provides a well-reinforced procedure for the PCB layout task as it pertains to the TPA300x series of class D amplifiers. This information can also be used in the layout of the TPA200x series, or any other class D audio amplifier.This task needs a logical sequence. If we simply jump into the layout task, without understanding how the circuits work, we risk not having an optimal end
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA3131D2 (2)
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments TPA3131D2RHBR
