Datasheet ТI ADS8557IPMR — Даташит
| Серия | ADS8557 |
| Модель | ADS8557IPMR |
670kSPS, 14-битный, 6-канальный АЦП с одновременной выборкой 64-LQFP от -40 до 125
ADS855x 16-, 14-, 12-Bit, Six-Channel, Simultaneous Sampling Analog-to-Digital Converters datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 3 фев 2016
- A Numerical Protection Relay SolutionPDF, 187 Кб, Файл опубликован: 2 сен 2010
Numerical Protection Relays (NPRs) are critical elements in any power distribution network. Generally, there are several different types of NPRs. Each type, however, shares a similar architecture, thus enabling designers to build an entire system solution that is based on a relatively small number of flexible components. This application note demonstrates how an NPR can be implemented using TI's e - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: ADS8557 (2)
- ADS8557IPM ADS8557IPMR
