Datasheet ТI TMP103CYFFR — Даташит
СерияTMP103
МодельTMP103CYFFR
Datasheet Texas Instruments TMP103CYFFR
Датчик температуры с напряжением 1,4 В и интерфейсом I2C/SMBus в WCSP 4-DSBGA от -40 до 125
TMP103 Low-Power, Digital Temperature Sensor With Two-Wire Interface in WCSP datasheet
PDF, 984 Кб, Версия: B, Файл опубликован: 6 янв 2016
  • SM72295 For Bi-Directional DC-to-DC Conversion (Rev. A)
    PDF, 3.7 Мб, Версия: A, Файл опубликован: 1 мар 2017
    To address ever tightening fuel economy demands the automotive industry is adopting two battery powersystems to facilitate Stop-Start operation in which the internal combustion engine shuts down whenstopped or coasting, and automatically restarts when power is applied. Typically a 12-V lead acid batterywill be used to power many of the car’s traditional systems, but a 48-V Lithium battery wi
  • Temperature sensors: PCB guidelines for surface mount devices (Rev. A)
    PDF, 5.6 Мб, Версия: A, Файл опубликован: 18 янв 2019
    Power hungry electronic components such as CPUs GPUs or FPGAs as well as voltage regulators heat up during operation. Some applications require ambient air temperature measurements while others need to measure the temperature of a nearby component on the PCB. Measuring ambient air temperature with a surface mount technology (SMT) device is challenging due to the thermal influence of other compo
  • AN-1112 DSBGA Wafer Level Chip Scale Package (Rev. AG)
    PDF, 13.7 Мб, Версия: AG, Файл опубликован: 12 авг 2015
  • Understanding the I2C Bus
    PDF, 124 Кб, Файл опубликован: 30 июн 2015
  • Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
На английском языке: Datasheet Texas Instruments TMP103CYFFR
Политика конфиденциальности
