Datasheet ТI OPA234PA — Даташит
| Серия | OPA234 |
| Модель | OPA234PA |
Маломощные прецизионные операционные усилители с однополярным питанием 8-PDIP
OPA234, 2234, 4234: Low Power, Precision Single-Supply Operational Amplifiers datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 10 апр 2008
- Stop-band limitations of the Sallen-Key, low-pass filterPDF, 573 Кб, Файл опубликован: 22 окт 2008
- Q4 2008 Issue Analog Applications JournalPDF, 1.5 Мб, Файл опубликован: 22 окт 2008
- Remove the DC Portion of Signals with the ADS7817PDF, 55 Кб, Файл опубликован: 27 сен 2000
Unwanted portions of a signal, such as a DC pedestal, can be difficult to reject in a single supply circuit. A DC pedestal voltage most typically appears at the output of an operational amplifier with a small signal riding on top of it. This pedestal voltage is required in the analog domain to insure that the small signal that contains the pertinent information never falls below the ground potenti - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA234 (18)
