Datasheet Linear Technology LT1394CS8#TRPBF — Даташит
| Серия | LT1394 |
| Модель | LT1394CS8#TRPBF |
7 нс, маломощный, однополярный, компаратор с датчиком заземления
Datasheet LT1394
PDF, 228 Кб, Язык: анг., Файл закачен: 7 авг 2017, Страниц: 16
7ns, Low Power, Single Supply, Ground-Sensing Comparator
- High Voltage, Low Noise, DC/DC Converters &mdash AN118PDF, 2.6 Мб, Файл опубликован: 28 мар 2008
Photomultipliers (PMT), avalanche photodiodes (APD), ultrasonic transducers, capacitance microphones, radiation detectors and similar devices require high voltage, low current bias. Additionally, the high voltage must be pristinely free of noise; well under a millivolt is a common requirement with a few hundred microvolts sometimes necessary. Normally, switching regulator conп¬Ѓgurations cannot achieve this performance level without employing special techniques. One aid to achieving low noise is that load currents rarely exceed 5mA. This freedom permits output п¬Ѓltering methods that are usually impractical.Выписка из документа - A Seven-Nanosecond Comparator for Single Supply Operation &mdash AN72PDF, 882 Кб, Файл опубликован: 1 май 1998
AN72 is an extensive discussion of the causes and cures of problems in very high speed comparator circuits. A separate applications section uses the 7ns LT1394 in V-to-F converters, crystal oscillators, clock skew generators, triggers, sampling configurations and a nanosecond pulse stretcher. Appendices cover related topics.Выписка из документа - 30 Nanosecond Settling Time Measurement for a Precision Wideband Amplifier &mdash AN79PDF, 624 Кб, Файл опубликован: 5 сен 1999
AN79 modifies methods presented in AN74, permitting verification of 30 nanosecond amplifier settling times to 0.1% resolution. The sampling-based technique used is detailed and results presented. Appendices cover oscilloscope overdrive issues, construction of a subnanosecond rise time pulse generator, amplifier compensation, circuit construction and calibration procedures.Выписка из документа - Low Noise Varactor Biasing with Switching Regulators: Vanquishing Villainous Vitiators Vis-Г -Vis Vital Varactors &mdash AN85PDF, 490 Кб, Файл опубликован: 1 авг 2000
Telecommunication, satellite links and set-top boxes all require tuning a high frequency oscillation. The actual tuning element, a varactor diode, requires high voltage bias for operation. The high voltage bias must be free of noise to prevent unwanted oscillator outputs. This publication details a method for generating noise free high voltage from low voltage inputs using switching regulators. Spurious oscillator outputs are below -90dBc. Suggested circuit and layout information is included. Appendices cover varactor diode theory and performance verification techniques.Выписка из документа
Design Notes
- A Seven Nanosecond Comparator for Single-Supply Operation &mdash DN185PDF, 86 Кб, Файл опубликован: 1 авг 1998Выписка из документа
- Rail-to-Rail I/O and 2.4V Operation Allow UltraFast Comparators to be Used on Low Voltage Supplies &mdash DN248PDF, 105 Кб, Файл опубликован: 1 янв 2001Выписка из документа
Статьи
- New UltraFast Comparators: Rail-to-Rail Inputs and 2.4V Operation Allow Use on Low Supplies &mdash LT JournalPDF, 194 Кб, Файл опубликован: 1 фев 2001Выписка из документа
- A 7ns, 6mA, Single-Supply Comparator Fabricated on Linear &mdash LT JournalPDF, 271 Кб, Файл опубликован: 1 май 1998Выписка из документа
- A 4.5ns, 4mA, Single-Supply, Dual Comparator Optimized for 3V/5V Operation &mdash LT JournalPDF, 287 Кб, Файл опубликован: 1 ноя 1998Выписка из документа
Серия: LT1394 (6)
- LT1394CMS8#PBF LT1394CMS8#TRPBF LT1394CS8#PBF LT1394CS8#TRPBF LT1394IS8#PBF LT1394IS8#TRPBF
- Signal Conditioning > Comparators > High Speed Comparators
LT1394CS8TRPBF, LT1394CS8 TRPBF
