Datasheet IRLR8103V - International Rectifier Даташит Полевой транзистор, N D-PAK — Даташит
Наименование модели: IRLR8103V
![]() 18 предложений от 13 поставщиков , 30V Single N-channel Hexfet Power Mosfet In A D-pak Package | |||
IRLR8103V International Rectifier | от 33 ₽ | ||
IRLR8103V Infineon | 82 ₽ | ||
IRLR8103V International Rectifier | от 378 ₽ | ||
IRLR8103V Infineon | по запросу |
Описание: Полевой транзистор, N D-PAK
PD-94021A
IRLR8103V
· · · · · N-Channel Application-Specific MOSFETs Ideal for CPU Core DC-DC Converters Low Conduction Losses Low Switching Losses Minimizes Parallel MOSFETs for high current applications
G D
Description This new device employs advanced HEXFET Power MOSFET technology to achieve an unprecedented balance of on-resistance and gate charge.
The reduced conduction and switching losses make it ideal for high efficiency DC-DC converters that power the latest generation of microprocessors. The IRLR8103V has been optimized for all parameters that are critical in synchronous buck converters including RDS(on), gate charge and Cdv/dt-induced turn-on immunity. The IRLR8103V offers an extremely low combination of Qsw & RDS(on) for reduced losses in both control and synchronous FET applications. The package is designed for vapor phase, infra-red, convection, or wave soldering techniques. Power dissipation of greater than 2W is possible in a typical PCB mount application.
- Continuous Drain Current Id: 91 А
- Drain Source Voltage Vds: 30 В
- On Resistance Rds(on): 7.9 МОм
- Корпус транзистора: TO-252
- SVHC: No SVHC (15-Dec-2010)
- Current Id Max: 91 А
- Тип корпуса: TO-252 (D-Pak)
- Power Dissipation Pd: 115 Вт
- Pulse Current Idm: 363 А
- Способ монтажа: SMD
- Voltage Vgs th Min: 1 В
Дополнительные аксессуары:
- Fischer Elektronik - FK 244 08 D PAK
- Fischer Elektronik - FK 244 13 D PAK
- Fischer Elektronik - WLK 5
