Datasheet IRFB4233PBF - International Rectifier Даташит Полевой транзистор, N, 230 В, TO-220 — Даташит
International Rectifier IRFB4233PBF
Наименование модели: IRFB4233PBF
Транзистор полевой N-канальный 230В 56А 370Вт
IRFB4233PBF
Infineon
102 ₽
727GS
IRFB4233PBF
Infineon
от 180 ₽
T-electron
IRFB4233PBF
IRFB4233PBF
Описание: Полевой транзистор, N, 230 В, TO-220
data sheetСкачать Data Sheet
PD - 97004
PDP SWITCH
Features l Advanced process technology l Key parameters optimized for PDP Sustain, Energy Recovery and Pass Switch Applications l Low EPULSE rating to reduce power dissipation in PDP Sustain, Energy Recovery and Pass Switch Applications l Low QG for fast response l High repetitive peak current capability for reliable operation l Short fall & rise times for fast switching l175°C operating junction temperature for improved ruggedness l Repetitive avalanche capability for robustness and reliability
IRFB4233PbF
Key Parameters
  • Continuous Drain Current Id: 56 А
  • Drain Source Voltage Vds: 230 В
  • On State Resistance: 37 Ом
  • Voltage Vgs Max: 30 В
  • Рабочий диапазон температрур: -40°C ...
    +175°C
  • Корпус транзистора: TO-220AB
  • SVHC: No SVHC (15-Dec-2010)
  • Avalanche Single Pulse Energy Eas: 250mJ
  • Capacitance Ciss Typ: 5510 пФ
  • Cont Current Id @ 100В°C: 39 А
  • Cont Current Id @ 25В°C: 56 А
  • Current Id Max: 56 А
  • Тип корпуса: TO-220AB
  • Power Dissipation Pd: 370 Вт
  • Pulse Current Idm: 220 А
  • Threshold Voltage Vgs Typ: 5 В
  • Voltage Vds: 230 В
  • Voltage Vds Typ: 276 В
  • Voltage Vgs Rds on Measurement: 10 В
  • Rth: 0.4
Дополнительные аксессуары:
  • Fischer Elektronik - SK 145/37,5 STS-220
  • Fischer Elektronik - SK 409/25,4 STS
  • Fischer Elektronik - SK 409/50,8 STS
На английском языке: Datasheet IRFB4233PBF - International Rectifier MOSFET, N, 230 V, TO-220
