Datasheet IRFB4020PBF - International Rectifier Даташит Полевой транзистор, N, 200 В, TO-220AB — Даташит
Наименование модели: IRFB4020PBF
![]() 57 предложений от 22 поставщиков IRFB4020 PBF MOSFET, N, 200V, TO-220AB; Transistor Type:MOSFET; Transistor Polarity:N; Voltage, Vds Typ:200V; Current, Id Cont:18A; Resistance, Rds On:0.1ohm; Voltage, Vgs... | |||
IRFB4020PBF Infineon | от 19 ₽ | ||
IRFB4020PBF International Rectifier | 55 ₽ | ||
IRFB4020PBF Infineon | 78 ₽ | ||
IRFB4020PBF Infineon | от 157 ₽ |
Описание: Полевой транзистор, N, 200 В, TO-220AB
PD - 97195
DIGITAL AUDIO MOSFET
Features
· Key parameters optimized for Class-D audio amplifier applications · Low RDSON for improved efficiency · Low QG and QSW for better THD and improved efficiency · Low QRR for better THD and lower EMI · 175°C operating junction temperature for ruggedness · Can deliver up to 300W per channel into 8 load in half-bridge configuration amplifier
G S D
- Continuous Drain Current Id: 18 А
- Drain Source Voltage Vds: 200 В
- On Resistance Rds(on): 100 МОм
- Voltage Vgs Max: 20 В
+175°C
- Корпус транзистора: TO-220AB
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Семейство: 4020
- Current Id Max: 18 А
- N-channel Gate Charge: 18nC
- Тип корпуса: TO-220AB
- Power Dissipation Pd: 100 Вт
- Pulse Current Idm: 52 А
- Способ монтажа: Through Hole
- Threshold Voltage Vgs Typ: 4.9 В
- Voltage Vds Typ: 200 В
- Voltage Vgs Rds on Measurement: 10 В
- Voltage Vgs th Max: 4.9 В
- Voltage Vgs th Min: 3 В
Дополнительные аксессуары:
- Fischer Elektronik - SK 409/25,4 STS
- Fischer Elektronik - SK 409/50,8 STS
- Fischer Elektronik - WLK 5
- Multicomp - MK3306
