Datasheet IRG4BC20KDPBF - International Rectifier Даташит IGBT, N, 600 В, 16 А, TO-220AB — Даташит
International Rectifier IRG4BC20KDPBF
Наименование модели: IRG4BC20KDPBF
Транзистор IGBT, Trans IGBT Chip N-CH 600V 16A 60000mW 3Pin(3+Tab) TO-220AB Tube
727GS
IRG4BC20KDPBF
Infineon
17 ₽
IRG4BC20KDPBF
Infineon
31 ₽
IRG4BC20KDPBF, IGBT 600В 9А 8-25кГц TO220AB
Infineon
208 ₽
МосЧип
IRG4BC20KDPBF
Описание: IGBT, N, 600 В, 16 А, TO-220AB
data sheetСкачать Data Sheet
PD -91599A
IRG4BC20KD
INSULATED GATE BIPOLAR TRANSISTOR WITH ULTRAFAST SOFT RECOVERY DIODE
Features
· Short Circuit Rated UltraFast: Optimized for high operating frequencies >5.0 kHz , and Short Circuit Rated to 10µs @ 125°C, VGE = 15V · Generation 4 IGBT design provides tighter parameter distribution and higher efficiency than previous generation · IGBT co-packaged with HEXFREDTM ultrafast, ultra-soft-recovery anti-parallel diodes for use in bridge configurations · Industry standard TO-220AB package
  • Тип транзистора: IGBT
  • DC Collector Current: 16 А
  • Collector Emitter Voltage Vces: 2.8 В
  • Power Dissipation Max: 60 Вт
  • Collector Emitter Voltage V(br)ceo: 600 В
  • Корпус транзистора: TO-220AB
  • Количество выводов: 3
  • Current Ic Continuous a Max: 16 А
  • Package / Case: TO-220AB
  • Power Dissipation: 60 Вт
  • Termination Type: Through Hole
  • Voltage Vces: 600 В
Дополнительные аксессуары:
  • Fischer Elektronik - WLK 5
На английском языке: Datasheet IRG4BC20KDPBF - International Rectifier IGBT, N, 600 V, 16 A, TO-220AB
