Datasheet Texas Instruments PCM1860QDBTRQ1 — Даташит
Серия | PCM1860-Q1 |
Модель | PCM1860QDBTRQ1 |
Автомобильный 103 дБ 2-канальный аппаратно-управляемый аудио АЦП с универсальным входным каскадом 30-TSSOP -40 до 125
PCM186x-Q1 Automotive, 4-Channel or 2-Channel, 192-kHz, Audio ADCs datasheet
PDF, 2.4 Мб, Версия: A, Файл опубликован: 21 июн 2017
Pin | 30 |
Package Type | DBT |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | PCM1860Q1 |
Width (мм) | 4.4 |
Length (мм) | 7.8 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
ADC Channels | 2 |
ADC SNR(Typ) | 103 дБ |
Additional Features | Analog Mic support,Energysense Signal Detection,PLL |
Analog Inputs | 8 |
Control Interface | H/W |
Digital Audio Interface | I2S,L |
Package Size: mm2:W x L | 30TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG |
Sampling Rate(Max) | 192 kHz |
- Evaluation Modules & Boards: PCM1860EVM
PCM1860 103dB 2-Ch Hardware-Controlled Audio ADC With Universal Front End Evaluation Module
- Optimizing Signal Chain Noise on PCM186x DevicesPDF, 213 Кб, Файл опубликован: 5 фев 2015
- Sitara Linux ALSA DSP Microphone Array Voice RecognitionPDF, 529 Кб, Файл опубликован: 30 июн 2017
Voice recognition applications requiring a superior user experience typically use a number of digital signal processing algorithms to filter, clean, and enhance microphone sampled audio. Frequently these systems will employ multiple microphones where more sophisticated algorithms can be used. These systems can leverage a Texas Instruments Digital Signal Processor to offload the complex real-time c - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1860-Q1 (1)
- PCM1860QDBTRQ1
- Semiconductors > Audio > Audio Converters > Audio ADC
