Datasheet Texas Instruments TPD4S012DRYR — Даташит
СерияTPD4S012
МодельTPD4S012DRYR
4-канальное USB-решение ESD с силовым зажимом 6-SON -40 to 85
TPD4S012 4-Channel ESD Solution for USB-HS/USB OTG/USB Charger Interface datasheet
PDF, 888 Кб, Версия: B, Файл опубликован: 2 июл 2014
Pin6
Package TypeDRY
Industry STD TermUSON
JEDEC CodeR-PDSO-N
Package QTY5000
Маркировка3B
Width (мм)1
Length (мм)1.45
Thickness (мм).5
Pitch (мм).5
Max Height (мм).6
Bi-/Uni-DirectionalUni-Directional
Breakdown Voltage(Min)20 В
Clamping Voltage8 В
Dynamic Resistance(Typ)1 Ω
IEC 61000-4-2 Air-Gap10 +/- kV
IEC 61000-4-2 Contact10 +/- kV
IO Capacitance(Typ)0.8 пФ
IO Leakage Current(Max)500 нА
InterfaceUSB 2.0
Количество каналов4
Package GroupSON
Package Size: mm2:W x LSee datasheet (SON) PKG
Special FeaturesN/A
  • Evaluation Modules & Boards: TUSB1210EVM
    TUSB1210 DP/DM Line External Component Compensation, Vbus Overvoltage Protection Circuit EVM
  • Evaluation Modules & Boards: BEAGLEBN
    BeagleBone Development Board
  • Evaluation Modules & Boards: ADS124S08EVM
    ADS124S08 Evaluation Module
  • Evaluation Modules & Boards: ADS127L01EVM
    ADS127L01 Evaluation Module
  • Development Kits: TMDSCNCD28379D
    F28379D controlCARD for C2000 Real time control development kits
  • Development Kits: TMDSDOCK28379D
    F28379D Delfino Experimenter Kit
  • Evaluation Modules & Boards: ADS122U04EVM
    ADS122U04 Evaluation Module
  • Evaluation Modules & Boards: DLPNIRSCANEVM
    DLPВ® NIRscanВ™ Evaluation Module
  • Evaluation Modules & Boards: ADS114S08EVM
    ADS114S08 Evaluation Module
  • Evaluation Modules & Boards: EVMK2G
    66AK2Gx (K2G) Evaluation Module
  • Reading and Understanding an ESD Protection Datasheet
    PDF, 2.5 Мб, Файл опубликован: 19 май 2010
    System engineers must choose all components for their designs carefully. Picking the right ESD protectionelements can be challenging as the matter of protecting devices on the PCB against ESD stress hasbecome an increasingly complex task.Texas Instruments offers a wide range of ESD protection elements. Understanding the datasheetparameters of ESD protection elements is paramount
  • Design Considerations for System-Level ESD Circuit Protection
    PDF, 381 Кб, Файл опубликован: 25 сен 2012
  • ESD Layout Guide
    PDF, 638 Кб, Файл опубликован: 4 мар 2015
Серия: TPD4S012 (1)
  • TPD4S012DRYR
  • Semiconductors > Interface > Circuit Protection > ESD Protection and TVS Surge Diodes
На английском языке: Datasheet Texas Instruments TPD4S012DRYR
