Datasheet Texas Instruments TPS2331IDRG4 — Даташит
СерияTPS2331
МодельTPS2331IDRG4
3-13 В одиночная ИС с возможностью горячей замены с отчетом о хорошем питании, активация высокого уровня 14-SOIC -40 до 85
Single Hot-Swap Power Controllers with Circuit Breaker and Power Good Reporting datasheet
PDF, 1.0 Мб, Версия: G, Файл опубликован: 10 май 2013
Контролер нагрузки, 3-13V Single Hot-Swap IC w/ Power Good Report, Act-High Enable 14-SOIC -40℃ to 85℃
Рутоника
TPS2331IDRG4
111 ₽
TPS2331IDRG4
145 ₽
TPS2331IDRG4
174 ₽
Hi-Tech Circuit Group
TPS2331IDRG4
Pin14
Package TypeD
Package QTY2500
МаркировкаTPS2331I
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Channel(s) Controlled1
Current Limit AccuracyAdjustable
Current Limit Function EnabledAlways
Current Limit Threshold(Typ)Adjustable Ext FET=mV
Current Measurement AccuracyN/A %
Design SupportCalculation Tool,EVM
Fault ResponseLatch Off
ON_OFF Control InputEN s
Status OutputFLT/,PG
Vabsmax_cont15 В
Vin(Max)13 В
Vin(Min)3 В
  • Evaluation Modules & Boards: TPS2301EVM-153
    TPS23XX Hot Swap Power Controllers Evaluation Module
  • Evaluation Modules & Boards: TPS2330EVM-184
    TPS2330 48-V Telecom Hot Swap Evaluation Module and Interface Card
  • A FET OR-ing Circuit For Fault Tolerant Power Systems
    PDF, 104 Кб, Файл опубликован: 17 май 2002
    Fault-tolerant power systems commonly achieve redundancy by diode OR-ing the outputs of several power supply modules. The OR-ing circuit is inefficient if the diode forward voltage drop represents a significant percentage of the load voltage. In low-voltage applications, a FET OR-ing circuit can be more efficient. This application note discusses the design and performance of a FET OR-ing circui
  • Protecting the TPS233x Hot-Swap Controller In a High Transient Environment
    PDF, 88 Кб, Файл опубликован: 31 янв 2008
    The TPS233x hot-swap controller has several pins tied to the power bus in a typical application. This exposes the TPS233x to potentially damaging transients whenever the TPS233x disconnects the load from the bus. Clamping the bus voltage with a transient voltage suppressor protects the TPS233x in some cases, but not in all cases. Additional protection can be gained by decoupling the TPS233x from t
  • +48V/-48V Hot-Swap Applications with TPS23xx Hot-Swap Controllers
    PDF, 79 Кб, Файл опубликован: 24 апр 2001
    The rapid development of telecommunication and networked systems has accelerated the growth of products requiring the hot-plug capability demanded by systems with a continuous uninterrupted power-on requirement. There are many hot-swap or hot-plug power management solutions available in the market today; however, the trick is picking the one that best suits the application's needs. Many applicatio
  • Step-By-Step Design Approach of TPS2300/01/10/11/20/21/30/31 Hotswap Controllers
    PDF, 169 Кб, Файл опубликован: 23 май 2003
    The TPS2300/01/10/11/20/21/30/31 hotswap controllers allow safe board insertion and removal from a live backplane. With the current-limit-setting resistor (RSET), the current limit can be set much more easily than other hotswap controllers. This report uses a simple step-by-step design approach to select the essential components and parameters for typical hotswap applications. By following the des
  • Power Management Solutions for Infiniband (SM) I/O Modules
    PDF, 75 Кб, Файл опубликован: 20 окт 2000
    InfiniBand, a scalable, modular, channel-based, switched-fabric architecture, is defined for the connection of servers with servers and with storage and networking devices. Because appropriate power management is essential for quality implementations, this report presents straightforward solutions for both high-power and low-power applications as required by the InfiniBand specification.
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > Hot Swap Controllers (Positive, -48V)
На английском языке: Datasheet Texas Instruments TPS2331IDRG4
