Datasheet FDC6301N - Fairchild Даташит Полевой транзистор, NN CH, 25 В, 0.22 А, SSOT6 — Даташит
Fairchild FDC6301N
Наименование модели: FDC6301N
48 предложений от 24 поставщиков
MOSFET 2N-CH 25V 0.22A SSOT6. Mosfet Array 2 N-Channel (Dual) 25V 220mA 700mW Surface Mount SuperSOTTM-6. Transistors - FETs, MOSFETs...
Рутоника
FDC6301N
7.80 ₽
FDC6301N
9.12 ₽
Эиком
FDC6301N
от 25 ₽
TradeElectronics
FDC6301N_NL
Fairchild
Производитель: Fairchild
Описание: Полевой транзистор, NN CH, 25 В, 0.22 А, SSOT6
data sheetСкачать Data Sheet
September 2001
FDC6301N Dual N-Channel , Digital FET
General Description
These dual N-Channel logic level enhancement mode field effect transistors are produced using Fairchild 's proprietary, high cell density, DMOS technology.
This very high density process is especially tailored to minimize on-state resistance. This device has been designed especially for low voltage applications as a replacement for digital transistors. Since bias resistors are not required, these N-Channel FET's can replace several digital transistors, with a variety of bias resistors.
Features
  • Continuous Drain Current Id: 220 мА
  • Drain Source Voltage Vds: 25 В
  • On Resistance Rds(on): 5 Ом
  • Rds(on) Test Voltage Vgs: 4.5 В
  • Threshold Voltage Vgs Typ: 850 мВ
  • Рассеиваемая мощность: 900 мВт
  • Рабочий диапазон температрур: -55°C ... +150°C
  • Корпус транзистора: SSOT
  • Количество выводов: 6
  • SVHC: No SVHC (19-Dec-2011)
  • Current Id Max: 220 мА
  • Тип корпуса: SSOT
  • Способ монтажа: SMD
  • Voltage Vds Typ: 25 В
  • Voltage Vgs Max: 850 мВ
  • Voltage Vgs Rds on Measurement: 2.7 В
На английском языке: Datasheet FDC6301N - Fairchild MOSFET, NN CH, 25 V, 0.22 A, SSOT6
