Datasheet RFD14N05L - Fairchild Даташит Полевой транзистор, N, LOGIC, I-PAK — Даташит
Наименование модели: RFD14N05L
![]() 39 предложений от 22 поставщиков Силовой МОП-транзистор, N Канал, 50 В, 14 А, 0.1 Ом, TO-251AA, Through Hole | |||
RFD14N05L ON Semiconductor | от 106 ₽ | ||
RFD14N05+L Fairchild | по запросу | ||
RFD14N05L_Q Fairchild | по запросу | ||
RFD14N05L Rochester Electronics | по запросу |
Производитель: Fairchild
Описание: Полевой транзистор, N, LOGIC, I-PAK
RFD14N05L, RFD14N05LSM
Data Sheet May 2010
14A, 50V, 0.100 Ohm, Logic Level, N-Channel Power MOSFETs
These are N-channel power MOSFETs manufactured using the MegaFET process.
This process, which uses feature sizes approaching those of LSI integrated circuits, gives optimum utilization of silicon, resulting in outstanding performance. They were designed for use in applications such as switching regulators, switching converters, motor drivers and relay drivers. This performance is accomplished through a special gate oxide design which provides full rated conductance at gate bias in the 3V-5V range, thereby facilitating true on-off power control directly from logic level (5V) integrated circuits. Formerly developmental type TA09870.
Features
- Continuous Drain Current Id: 14 А
- Drain Source Voltage Vds: 50 В
- On Resistance Rds(on): 100 МОм
- Rds(on) Test Voltage Vgs: 5 В
- Voltage Vgs Max: 2 В
- Рабочий диапазон температрур: -55°C ... +175°C
- Корпус транзистора: I-PAK
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Альтернативный тип корпуса: I-PAK
- Current Id Max: 14 А
- Current Temperature: 25°C
- Количество транзисторов: 1
- Тип корпуса: IPAK
- Power Dissipation Pd: 48 Вт
- Pulse Current Idm: 20 А
- Способ монтажа: Through Hole
- Threshold Voltage Vgs Typ: 2 В
- Voltage Vds Typ: 50 В
- Voltage Vgs Rds on Measurement: 5 В
- Voltage Vgs th Max: 2 В
RoHS: Y-Ex
Дополнительные аксессуары:
- Fischer Elektronik - FK 244 13 D PAK
- Fischer Elektronik - WLK 5
- Panasonic - EYGA121807A
- Roth Elektronik - RE901
