Datasheet RFP70N06 - Fairchild Даташит Полевой транзистор, N, TO-220 — Даташит
Наименование модели: RFP70N06
![]() 51 предложений от 28 поставщиков Силовой МОП-транзистор, N Канал, 60 В, 70 А, 0.014 Ом, TO-220AB, Through Hole | |||
RFP70N06 ON Semiconductor | от 141 ₽ | ||
RFP70N06 ON Semiconductor | 173 ₽ | ||
RFP70N06_NL Fairchild | по запросу | ||
RFP70N06H444 Fairchild | по запросу |
Производитель: Fairchild
Описание: Полевой транзистор, N, TO-220
RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM
Data Sheet January 2002
70A, 60V, 0.014 Ohm, N-Channel Power MOSFETs
These are N-Channel power MOSFETs manufactured using the MegaFET process.
This process, which uses feature sizes approaching those of LSI circuits, gives optimum utilization of silicon, resulting in outstanding performance. They were designed for use in applications such as switching regulators, switching converters, motor drivers and relay drivers. These transistors can be operated directly from integrated circuits. Formerly developmental type TA78440.
Features
- Continuous Drain Current Id: 70 А
- Drain Source Voltage Vds: 60 В
- On Resistance Rds(on): 14 МОм
- Voltage Vgs Max: 4 В
- Корпус транзистора: TO-220AB
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Current Id Max: 70 А
- Current Temperature: 25°C
- Маркировка: RFP70N06
- Количество транзисторов: 1
- On State Resistance Max: 14 МОм
- Тип корпуса: TO-220AB
- Power Dissipation Pd: 150 Вт
- Pulse Current Idm: 180 А
- Способ монтажа: Through Hole
- Threshold Voltage Vgs Typ: 4 В
- Voltage Vds Typ: 60 В
- Voltage Vgs Rds on Measurement: 10 В
- Voltage Vgs th Max: 4 В
Дополнительные аксессуары:
- Fischer Elektronik - SK 145/37,5 STS-220
- Fischer Elektronik - SK 409/25,4 STS
- Fischer Elektronik - SK 409/50,8 STS
- Fischer Elektronik - WLK 5
