Datasheet HUF75307D3 - Fairchild Даташит Полевой транзистор, N I-PAK — Даташит
Fairchild HUF75307D3
Наименование модели: HUF75307D3
19 предложений от 19 поставщиков
, Power Field-Effect Transistor, 13A I(D), 55V, 0.09ohm, 1-Element, N-Channel, Silicon, Metal-oxide Semiconductor FET, TO-252AA
727GS
HUF75307D3
37 ₽
HUF75307D3ST_NL
Fairchild
70 ₽
Эиком
HUF75307D3ST_NL
Fairchild
76 ₽
МосЧип
HUF75307D3ST136
Fairchild
Решения для систем охлаждения
Производитель: Fairchild
Описание: Полевой транзистор, N I-PAK
data sheetСкачать Data Sheet
HUF75307P3, HUF75307D3, HUF75307D3S
Data Sheet June 1999 File Number
4353.6
15A, 55V, 0.090 Ohm, N-Channel UltraFET Power MOSFETs
These N-Channel power MOSFETs are manufactured using the innovative UltraFETTM process.
This advanced process technology achieves the lowest possible on-resistance per silicon area, resulting in outstanding performance. This device is capable of withstanding high energy in the avalanche mode and the diode exhibits very low reverse recovery time and stored charge. It was designed for use in applications where power efficiency is important, such as switching regulators, switching converters, motor drivers, relay drivers, lowvoltage bus switches, and power management in portable and battery-operated products. Formerly developmental type TA75307.
  • Continuous Drain Current Id: 13 А
  • Drain Source Voltage Vds: 55 В
  • On Resistance Rds(on): 90 МОм
  • Корпус транзистора: TO-251
  • SVHC: No SVHC (15-Dec-2010)
  • Current Temperature: 25°C
  • Lead Length: 9.65 мм
  • Расстояние между выводами: 2.28 мм
  • Количество транзисторов: 1
  • Тип корпуса: TO-251 (I-Pak)
  • Power Dissipation Pd: 35 Вт
  • Время выключения: 45 нс
  • Время включения: 40 нс
На английском языке: Datasheet HUF75307D3 - Fairchild MOSFET, N I-PAK
