Datasheet IRF6215PBF - International Rectifier Даташит Полевой транзистор, P, TO-220 — Даташит
Наименование модели: IRF6215PBF
![]() 19 предложений от 15 поставщиков MOSFET, Power; P-Ch; VDSS -150V; RDS(ON) 0.29Ω; ID -13A; TO-220AB; PD 110W; VGS +/-20 | |||
MOSFET транзистор IRF6215PBF SP001559672 IRF Infineon | 56 ₽ | ||
IRF6215PBF Infineon | 87 ₽ | ||
IRF6215PBF Infineon | 460 ₽ | ||
IRF6215PBF Infineon | по запросу |
Описание: Полевой транзистор, P, TO-220
PD - 94817
IRF6215PbF
Advanced Process Technology Dynamic dv/dt Rating 175°C Operating Temperature Fast Switching P-Channel Fully Avalanche Rated Lead-Free Description
Fifth Generation HEXFETs from International Rectifier utilize advanced processing techniques to achieve extremely low on-resistance per silicon area.
This benefit, combined with the fast switching speed and ruggedized device design that HEXFET Power MOSFETs are well known for, provides the designer with an extremely efficient and reliable device for use in a wide variety of applications. The TO-220 package is universally preferred for all commercial-industrial applications at power dissipation levels to approximately 50 watts. The low thermal resistance and low package cost of the TO-220 contribute to its wide acceptance throughout the industry.
HEXFET® Power MOSFET
- Полярность транзистора: P Channel
- Continuous Drain Current Id: 13 А
- Drain Source Voltage Vds: 150 В
- On Resistance Rds(on): 290 МОм
- Rds(on) Test Voltage Vgs: -10 В
- Voltage Vgs Max: -4 В
- Корпус транзистора: TO-220AB
- Количество выводов: 3
- SVHC: No SVHC (15-Dec-2010)
- Avalanche Single Pulse Energy Eas: 310mJ
- Current Id Max: -13 А
- Current Temperature: 25°C
- Расстояние между выводами: 2.54 мм
- Количество транзисторов: 1
- Тип корпуса: TO-220AB
- Power Dissipation Pd: 110 Вт
- Рассеиваемая мощность максимальная: 110 Вт
- Pulse Current Idm: 44 А
- Способ монтажа: Through Hole
- Threshold Voltage Vgs Typ: -4 В
- Voltage Vds: 150 В
- Voltage Vds Typ: -150 В
- Voltage Vgs Rds on Measurement: -10 В
Дополнительные аксессуары:
- Fischer Elektronik - SK 145/37,5 STS-220
- Fischer Elektronik - SK 409/25,4 STS
- Fischer Elektronik - SK 409/50,8 STS
- Fischer Elektronik - WLK 5
