Datasheet IRLU014NPBF - International Rectifier Даташит Полевой транзистор, N, 55 В, 10 А, I-PAK — Даташит
International Rectifier IRLU014NPBF
Наименование модели: IRLU014NPBF
Труба MOS, Trans MOSFET N-CH 55V 10A 3Pin(3+Tab) IPAK
727GS
IRLU014NPBF
Infineon
45 ₽
IRLU014NPBF
74 ₽
IRLU014NPBF
Infineon
126 ₽
IRLU014NPBF
Infineon
Описание: Полевой транзистор, N, 55 В, 10 А, I-PAK
data sheetСкачать Data Sheet
PD- 94350
IRLR/U014N
HEXFET® Power MOSFET
Logic-Level Gate Drive Surface Mount (IRLR024N) Straight Lead (IRLU024N) Advanced Process Technology Fast Switching Fully Avalanche Rated Description
Fifth Generation HEXFETs from International Rectifier utilize advanced processing techniques to achieve the lowest possible on-resistance per silicon area.
This benefit, combined with the fast switching speed and ruggedized device design that HEXFET Power MOSFETs are well known for, provides the designer with an extremely efficient device for use in a wide variety of applications. The D-PAK is designed for surface mounting using vapor phase, infrared, or wave soldering techniques. The straight lead version (IRFU series) is for through-hole mounting applications. Power dissipation levels up to 1.5 watts are possible in typical surface mount applications.
  • Continuous Drain Current Id: 10 А
  • Drain Source Voltage Vds: 55 В
  • On Resistance Rds(on): 140 МОм
  • Voltage Vgs Max: 1 В
  • Корпус транзистора: I-PAK
  • Количество выводов: 3
  • SVHC: No SVHC (15-Dec-2010)
  • Альтернативный тип корпуса: I-PAK
  • Current Id Max: 10 А
  • Тепловое сопротивление переход-корпус: 5.3°C/W
  • On State resistance @ Vgs = 10V: 140 МОм
  • Тип корпуса: IPAK
  • Power Dissipation Pd: 28 Вт
  • Pulse Current Idm: 40 А
  • Threshold Voltage Vgs Typ: 1 В
  • Voltage Vds Typ: 55 В
  • Voltage Vgs Rds on Measurement: 10 В
  • Voltage Vgs th Min: 1 В
RoHS: Y-Ex
Дополнительные аксессуары:
  • Fischer Elektronik - FK 244 13 D PAK
  • Fischer Elektronik - WLK 5
  • Panasonic - EYGA121807A
  • Roth Elektronik - RE901
На английском языке: Datasheet IRLU014NPBF - International Rectifier MOSFET, N, 55 V, 10 A, I-PAK
