Datasheet AD9694 (Analog Devices) - 18
ОписаниеQuad 14-Bit, 500 MSPS, 1.2 V/2.5 V Analog-to-Digital Converter
Страниц / Страница102 / 18 — Data Sheet. AD9694. 2.0. 1.85. 1.5. 1.80. 1.75. 1.0. 1.70. 0.5. ) B. (W …
ВерсияB
Формат / Размер файлаPDF / 2.7 Мб
Data Sheet. AD9694. 2.0. 1.85. 1.5. 1.80. 1.75. 1.0. 1.70. 0.5. ) B. (W 1.65. L (. W 1.60. –0.5. 1.55. –1.0. 1.50. –1.5. 1.45. –2.0. 1.40. 250. 300. 350. 400. 450. 500. 550. 600
Data Sheet AD9694 2.0 1.85 1.5 1.80 1.75 1.0 1.70 0.5 ) B (W 1.65 L ( W 1.60 –0.5 1.55 –1.0 1.50 –1.5 1.45 –2.0 1.40 250 300 350 400 450 500 550 600
Микросхема Преобразователь AD, Quad Channel Quad ADC Pipelined 500MSPS 14Bit JESD204B 72Pin LFCSP EP Tray
ЧипСити
AD9694BCPZ-500
58 638 ₽
AD9694BCPZ-500
58 638 ₽
AD9694BCPZ-500
60 750 ₽
Эиком
AD9694BCPZ-500
141 577 ₽
Data Sheet AD9694 2.0 1.85 1.5 1.80 1.75 1.0 1.70 0.5 ) ) B (W 1.65 LS 0 ER L ( W 1.60 IN PO –0.5 1.55 –1.0 1.50 –1.5 1.45 –2.0 1.40 0 250 300 350 400 450 500 550 600 650
122
1024 2048 3072 4096 5120 6144 7168 8192 9216
18
SAMPLE RATE (MSPS) 10240 11264 12288 13312 14336 15360 16384
1 14808-
OUTPUT CODE
14808- Figure 24. INL, f Figure 27. Power Dissipation vs. Sample Rate (fS) IN = 10.3 MHz
1.0 0 AIN = –1dBFS SNRFS = 65.94dB 0.8 –20 SFDR = 89.01dBFS 0.6 –40 0.4 S) F –60 B 0.2 B) S E (d L D ( 0 –80 U IT DNL –0.2 –100 MPL A –0.4 –120 –0.6 –140 –0.8 –1.0 –160 0 –125 –75 –25 25 75 125
123
19
FREQUENCY (MHz) 10240 11264 12288 13312 14336 15360 16384
1 14808-
OUTPUT CODE
14808- Figure 25. DNL, f Figure 28. DDC Mode (4 DDCs; Decimate by 2; L = 2, M = 4, and F = 4) IN = 10.3 MHz with fIN = 305 MHz
0 6000 AIN = –1dBFS SNRFS = 71.80dB –20 SFDR = 98.27dBFS 5000 –40 S) S 4000 F T –60 B HI F E (d D –80 U R O 3000 IT BE –100 MPL NUM 2000 A –120 1000 –140 –160 0 0 5 5 5 0 5 5 5 5 1 2 3 4 5 6 7 8 9 10 17. 37. 57. 62. N – 9 N – 8 N – 7 N – 6 N – 5 N – 4 N – 3 N – 2 N – 1 N + N + N + N + N + N + N + N + N + –62. –42. –22.
124
N – 10 N +
120
FREQUENCY (MHz) CODE
14808- 14808- Figure 26. Input Referred Noise Histogram Figure 29. DDC Mode (4 DDCs; Decimate by 4; L = 1, M = 4, and F = 8) with fIN = 305 MHz Rev. 0 | Page 17 of 101 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY GENERAL DESCRIPTION PRODUCT HIGHLIGHTS SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Dither Differential Input Configurations Input Common Mode Analog Input Controls and SFDR Optimization Absolute Maximum Input Swing VOLTAGE REFERENCE DC OFFSET CALIBRATION CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Input Clock Divider Clock Jitter Considerations Power-Down/Standby Mode Temperature Diode ADC OVERRANGE AND FAST DETECT ADC OVERRANGE FAST THRESHOLD DETECTION (FD_A, FD_B, FD_C, AND FD_D) SIGNAL MONITOR SPORT OVER JESD204B DIGITAL DOWNCONVERTER (DDC) DDC I/Q INPUT SELECTION DDC I/Q OUTPUT SELECTION DDC GENERAL DESCRIPTION FREQUENCY TRANSLATION GENERAL DESCRIPTION Variable IF Mode 0 Hz IF (ZIF) Mode fS/4 Hz IF Mode Test Mode DDC NCO AND MIXER LOSS AND SFDR NUMERICALLY CONTROLLED OSCILLATOR Setting Up the NCO FTW and POW NCO Synchronization Mixer FIR FILTERS OVERVIEW HALF-BAND FILTERS HB4 Filter HB3 Filter HB2 Filter HB1 Filter DDC GAIN STAGE DDC COMPLEX TO REAL CONVERSION DDC EXAMPLE CONFIGURATIONS DIGITAL OUTPUTS INTRODUCTION TO THE JESD204B INTERFACE SETTING UP THE AD9694 DIGITAL INTERFACE FUNCTIONAL OVERVIEW Transport Layer Data Link Layer Physical Layer JESD204B LINK ESTABLISHMENT Code Group Synchronization (CGS) and SYNCINB± Initial Lane Alignment Sequence (ILAS) User Data and Error Detection 8B/10B Encoder PHYSICAL LAYER (DRIVER) OUTPUTS Digital Outputs, Timing, and Controls De-Emphasis Phase-Locked Loop (PLL) JESD204B Tx CONVERTER MAPPING CONFIGURING THE JESD204B LINK Example 1: Full Bandwidth Mode Example 2: ADC with DDC Option (Two ADCs Plus Two DDCs in Each Pair) LATENCY END-TO-END TOTAL LATENCY MULTICHIP SYNCHRONIZATION SYSREF± SET UP AND HOLD WINDOW MONITOR TEST MODES ADC TEST MODES JESD204B BLOCK TEST MODES Transport Layer Sample Test Mode Interface Test Modes Data Link Layer Test Modes SERIAL PORT INTERFACE CONFIGURATION USING THE SPI HARDWARE INTERFACE SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Unassigned and Reserved Locations Default Values Logic Levels ADC Pair Addressing Channel Specific Registers SPI Soft Reset MEMORY MAP REGISTER TABLE SUMMARY MEMORY MAP REGISTER TABLE—DETAILS APPLICATIONS INFORMATION POWER SUPPLY RECOMMENDATIONS EXPOSED PAD THERMAL HEAT SLUG RECOMMENDATIONS AVDD1_SR (PIN 64) AND AGND_SR (PIN 63 AND PIN 67) OUTLINE DIMENSIONS ORDERING GUIDE
