Datasheet ADXL1001, ADXL1002 (Analog Devices) - 14
Описание | Low Noise, High Frequency +/-50g MEMS Accelerometer |
Страниц / Страница | 14 / 14 — ADXL1001/ADXL1002. Data Sheet. OUTLINE DIMENSIONS. DETAIL A. (JEDEC 95). … |
Формат / Размер файла | PDF / 763 Кб |
Язык документа | английский |
ADXL1001/ADXL1002. Data Sheet. OUTLINE DIMENSIONS. DETAIL A. (JEDEC 95). 5.10. 0.30. 5.00 SQ. 0.25. PIN 1. 4.90. 0.20
ADXL1001/ADXL1002 Data Sheet OUTLINE DIMENSIONS DETAIL A (JEDEC 95) 5.10 0.30 5.00 SQ 0.25 PIN 1 4.90 0.20 PIN 1 INDIC ATOR AREA OPTIONS INDICATOR (SEE DETAIL A) 25 32 24 1 0.50 BSC EXPOSED 3.80 PAD 3.70 SQ 3.60 8 17 16 9 0.45 TOP VIEW BOTTOM VIEW 0.20 MIN 0.40 0.35 3.50 REF *1.85 1.80 0.05 MAX FOR PROPER CONNECTION OF 1.75 THE EXPOSED PAD, REFER TO 0.02 NOM THE PIN CONFIGURATION AND COPLANARITY FUNCTION DESCRIPTIONS SEATING 0.08 SECTION OF THIS DATA SHEET. PLANE 0.203 REF A 2017- * -004829 COMPLIANT TO JEDEC STANDARDS MO-220-VHHD-4 02- G K P WITH EXCEPTION TO PACKAGE HEIGHT. 02-
Figure 29. 32-Lead Lead Frame Chip Scale Package (LFCSP) 5 mm × 5 mm Body and 1.8 mm Package Height (CP-32-26) Dimensions shown in millimeters
ORDERING GUIDE Model1 Temperature Range g Range Package Description Package Option
ADXL1001BCPZ −40°C to +125°C ±100 g 32-Lead Lead Frame Chip Scale Package [LFCSP] CP-32-26 ADXL1001BCPZ-RL −40°C to +125°C ±100 g 32-Lead Lead Frame Chip Scale Package [LFCSP] CP-32-26 ADXL1001BCPZ-RL7 −40°C to +125°C ±100 g 32-Lead Lead Frame Chip Scale Package [LFCSP] CP-32-26 ADXL1002BCPZ −40°C to +125°C ±50 g 32-Lead Lead Frame Chip Scale Package [LFCSP] CP-32-26 ADXL1002BCPZ-RL −40°C to +125°C ±50 g 32-Lead Lead Frame Chip Scale Package [LFCSP] CP-32-26 ADXL1002BCPZ-RL7 −40°C to +125°C ±50 g 32-Lead Lead Frame Chip Scale Package [LFCSP] CP-32-26 EVAL-ADXL1002Z ADXL1002 Evaluation Board EVAL-ADXL1001Z ADXL1001 Evaluation Board 1 Z = RoHS Compliant Part.
©2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D15431-0-3/17(0)
Rev. 0 | Page 14 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE RECOMMENDED SOLDERING PROFILE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL DEVICE OPERATION OPERATING MODES Measurement Mode Standby BANDWIDTH APPLICATIONS INFORMATION APPLICATION CIRCUIT ON DEMAND SELF TEST RATIOMETRIC OUTPUT VOLTAGE INTERFACING ANALOG OUTPUT BELOW 10 kHz INTERFACING ANALOG OUTPUT BEYOND 10 kHz OVERRANGE MECHANICAL CONSIDERATIONS FOR MOUNTING LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
