Catalog CR Magnetics Transducers, Relays, Transformers, Indicators (CR Magnetics) - 37
ПроизводительCR Magnetics
ОписаниеSelection Guide
Страниц / Страница38 / 37 — Low Cost Remote Current Indicator. CR2550. Features. Applications. …
Формат / Размер файлаPDF / 1.6 Мб
Low Cost Remote Current Indicator. CR2550. Features. Applications. Specifications. Turn-on point:. Part Numbers
Low Cost Remote Current Indicator CR2550 Features Applications Specifications Turn-on point: Part Numbers
The
CR2550
series Remote Current Indicators are designed as a low cost method for providing a visu- al indication of electrical current flow. The current- carrying wire is routed through the window opening in the current sensing transformer. Attached to the transformer is a high efficiency, bi-polar LED that illuminates when the current is above the turn-on point. The indicator is available as standard with an 11 inch long lead and a red or green LED indicator.
Features
• Low cost for high volume OEM installations
Applications
• Low fixed trip point • • Fully isolated Indicate open heater element • • Easy to install Observe remote loads • • Self-powered Indicate phase loss • Monitor motor operation
0.75 Aac RMS for Red LED
Part Numbers
1.5 Aac RMS for Green LED
Maximum Continuous Rating: CR2550-11-.75 R CURRENT INDICATOR WITH
20 Aac RMS
RED LED Frequency: CR2550-11-1.5 G CURRENT INDICATOR WITH
50 to 400 HZ
GREEN LED Operating Temperature:
-30 °C to +60 °C
Installation Storage Temperature:
-55 °C to +85 °C
LED Indicator type:
T-13/4, Bipolar, Red/Red or Green/Green Diffused, Indicator is supplied with LED attached to current sensing transformer
LED Mounting Hardware:
Supplied with both one-piece press-in lens and two- piece mounting clip
Outline Drawing
.062 (1.6) MIN. .125 (3.2) MAX. .250 (6.4) ± .002 Dia. Hole
ONE PIECE RED LENS M
TWO PIECE MOUNTING CLIP
36
