Datasheet K857PE (Vishay) - 5
ПроизводительVishay
Описание4-Quadrant Silicon PIN Photodiode
Страниц / Страница7 / 5 — K857PE. TAPE AND REEL DIMENSIONS. Notes
Формат / Размер файлаPDF / 247 Кб
K857PE TAPE AND REEL DIMENSIONS Notes
30 предложений от 7 поставщиков
Photodiode, AEC-Q101, 4-Quadrant, 840 nm, 60 deg
K857PE
от 23 ₽
Зенер
Россия и страны ТС
K857PE
от 66 ₽
Эиком
K857PE
от 170 ₽
Элитан
K857PE
171 ₽
K857PE
www.vishay.com Vishay Semiconductors
in millimeters 40.00 ± 0.20 (3) (1) Section Y - Y + 0.10 0.30 ± 0.05 4.00 ± 0.10 Ø1.50 -0.00 2.00 ± 0.05 (1) Y 1.75 ± 0.10 5.50 ± 0.05 5.00 ± 0.05 12.00 ± 0.30 K8XX VYXXXXX 8° max. Marking pin 1 Y Ø1.50 min. 8.00 ± 0.10 (2) X X 5.00 ± 0.05 1.005 ± 0.05 8° max. Section X - X Leader Trailer
Notes
• Allowable camber to be 1 mm per 250 mm in length for single winding and 2 mm per 250 mm in length for cross winding (1) Measure from centerline of sprocket hole to centerline of pocket (2) Measure from centerline of pocket to centerline of pocket (3) Pitch tolerance for sprocket hole, 10 pitch cumulative tolerance is ± 0.2 mm Rev. 1.0, 10-Sep-2020
5
Document Number: 80136 For technical questions, contact: detectortechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
