Datasheet HCPL-7800A, HCPL-7800 (Broadcom) - 7
ПроизводительBroadcom
ОписаниеIsolation Amplifier
Страниц / Страница20 / 7 — HCPL-7800A/HCPL-7800. DC Electrical Specifications. Parameter. Symbol. …
Формат / Размер файлаPDF / 829 Кб
HCPL-7800A/HCPL-7800. DC Electrical Specifications. Parameter. Symbol. Min. Typ. Max. Units. Test Conditions. Figure. Note
HCPL-7800A/HCPL-7800 DC Electrical Specifications Parameter Symbol Min Typ Max Units Test Conditions Figure Note
72 предложений от 33 поставщиков
Оптопара, усилители с оптической развязкой, 1 канал, Поверхностный Монтаж DIP, 8 вывод(-ов)
Элитан
HCPL-7800A-500E
255 ₽
Триема
HCPL7800A-500E
332 ₽
HCPL-7800A-500E
Broadcom
от 1 248 ₽
HCPL7800A#50Y
link to page 9 link to page 9 link to page 9 link to page 10 link to page 10 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 11
Data Sheet Isolation Amplifer
Unless otherwise noted, all typicals and figures are at the nominal operating conditions of VIN+ = 0V, VIN– = 0V, VDD1 = VDD2 = 5V and TA = 25°C; all Min./Max. specifications are within the recommended operating conditions.
Parameter Symbol Min. Typ. Max. Units Test Conditions Figure Note
Input Offset Voltage VOS –2.0 0.3 2.0 mV TA = 25°C 2, 3 –3.0 — 3.0 –40°C < TA < +85°C, –4.5V < (VDD1, VDD2) < 5.5V Magnitude of Input Offset |DVOS/DTA| — 3.0 10.0 µV/°C 4 a Change vs. Temperature Gain (HCPL-7800A) G1 7.92 8.00 8.08 V/V –200 mV < VIN+ < 200 mV, 5, 6, 7 b T Gain (HCPL-7800) G A = 25°C 3 7.76 8.00 8.24 Magnitude of VOUT Gain |DG/DTA| — 0.00025 — V/V/°C c Change vs.Temperature VOUT 200 mV Nonlinearity NL200 — 0.0037 0.35 % –200 mV < VIN+ < 200 mV 8, 9 d Magnitude of VOUT 200 mV |dNL200/dT| — 0.0002 — % / °C Nonlinearity Change vs. Temperature VOUT 100 mV Nonlinearity NL100 — 0.0027 0.2 % –100 mV < VIN+ < 100 mV e Maximum Input Voltage |VIN+|MAX — 308.0 — mV 10 before VOUT Clipping Input Supply Current IDD1 — 10.86 16.0 mA VIN+ = 400 mV 11 f Output Supply Current IDD2 — 11.56 16.0 VIN+ = –400 mV g Input Current IIN+ — –0.5 5.0 µA 12 h Magnitude of Input Bias |dIIN/dT| — 0.45 — nA/°C Current vs. Temperature Coefficient Output Low Voltage VOL — 1.29 — V i Output High Voltage VOH — 3.80 — V Output Common-Mode VOCM 2.2 2.545 2.8 V Voltage Output Short-Circuit Current |IOSC| — 18.6 — mA j Equivalent Input Impedance RIN — 500 — kΩ VOUT Output Resistance ROUT — 15 — Ω Input DC Common-Mode CMRRIN — 76 — dB k Rejection Ratio a. This is the Absolute Value of Input Offset Change vs. Temperature. b. Gain is defined as the slope of the best-fit line of differential output voltage (VOUT+ – VOUT–) vs. differential input voltage (VIN+ – VIN–) over the specified input range. c. This is the Absolute Value of Gain Change vs. Temperature. d. Nonlinearity is defined as half of the peak-to-peak output deviation from the best-fit gain line, expressed as a percentage of the full-scale differential output voltage. e. NL100 is the nonlinearity specified over an input voltage range of ±100 mV. f. The input supply current decreases as the differential input voltage (VIN+ – VIN–) decreases. Broadcom AV02-0410EN 7 Document Outline Description Features Applications Functional Diagram Ordering Information Package Outline Drawings Standard DIP Package Gull Wing Surface Mount Option 300 Solder Reflow Profile Regulatory Information IEC/EN/DIN EN 60747-5-5 Insulation Characteristics Insulation and Safety-Related Specifications Absolute Maximum Ratings Recommended Operating Conditions DC Electrical Specifications AC Electrical Specifications Package Characteristics Application Information Power Supplies and Bypassing PC Board Layout Current Sensing Resistors Sense Resistor Connections Output Side Frequently Asked Questions about the HCPL-7800(A) Basics Sense Resistor and Input Filter Isolation and Insulation Accuracy Power Supplies and Start-Up Miscellaneous
