Ноутбук Dell PP18L LA2791P. Никаких признаков жизни
06.03.2013 15:37 #1
Напряжение питания + 20В
ID источника измеряемого напряжения по отношению к земле: 3.15V
При нажатии на кнопку выключения привел власти в течение нескольких секунд и выходит вскоре после
Не наблюдалось никаких компонентов с тепловым
Даже с учетом аккумулятора, индикатор батареи не горит
06.03.2013 15:54 #2
In "ingleze"version,please,dear eletmoraes...
06.03.2013 17:27 #3
Notebook Dell PP18L LA2791P league and a few seconds later turns off
Working only with the motherboard + CPU + memory + keyboard, AC adapter and battery. The Notebook by pressing the power button (which is on the keyboard itself) provides no image on the LCD screen and not the external monitor and also the LED that indicates that the battery is connected is off.
The source AC adapter is plugged in motherboard and when I press the power button, the LED lights up only the power for a few seconds and turns off soon after.
There are no signs of overheating components.
v + supply voltage is 20VDC
Voltage ID (control) of the source is of 3.15VDC measured with respect to ground
No picture on the LCD screen and the external display also
Checked voltage at pin 27 (LX3) of the MAX8734 is 3V15
Checked voltage at pin 15 (LX5) of the MAX8734 is 5V
voltage (+15 V_SUSP) was checked and confers
Часовой пояс GMT +3, время: 06:16.
