User manual RT-ZF1 USB 2.0 Compliance Test Fixture Set (Rohde&Schwarz) - 7
ПроизводительRohde&Schwarz
ОписаниеRT-ZF1 USB 2.0 Compliance Test Fixture Set Manual
Страниц / Страница19 / 7 — R&S. RT-ZF1. Product Description. Risk of burning caused by …
Версия06.00
Формат / Размер файлаPDF / 6.7 Мб
R&S. RT-ZF1. Product Description. Risk of burning caused by overheating of the load board. 2.1.2. Accessories. Item. Quantity
R&S RT-ZF1 Product Description Risk of burning caused by overheating of the load board 2.1.2 Accessories Item Quantity
R&S
Test Equipment
The load board gets hot during testing. To avoid injuries, observe the fol- lowing instructions: ● Do not touch the board when a test is running. ● After finishing the tests, set all switches to their middle position and wait at least 5 min until the module cools down. ● Touch the board only at switches and edges. Do not touch the surface of the board.
2.1.2 Accessories
The following accessories are supplied with the USB 2.0 test fixture boards:
Item Quantity Order number
USB cable type A to type B, length 20 cm 2 3589.2124.00 USB cable type A to type B, length 1.3 m 2 0041.9177.00 USB Adapter, type A to mini 1 3589.2147.00 USB adapter, type A to micro-B 1 3589.2130.00 SMA cable, length 1 m, to connect the signal generator 2 1142.5889.00 Carrying case 1 Manual 1
2.2 Test Equipment
For USB 2.0 compliance tests, the following test equipment is recommended: ● R&S RTO oscilloscope with 4 channels and at least 2 GHz bandwidth. For full speed and low speed compliance tests, a 4-channel R&S RTO with less than 2 GHz bandwidth is sufficient. Manual 1317.4326.02 ─ 06
7
Document Outline Cover Contents 1 Usage Information 2 Product Description 2.1 Deliveries 2.1.1 Boards 2.1.2 Accessories 2.2 Test Equipment 2.3 Specifications 3 Connections and Switches 3.1 Oscilloscope Connections 3.2 Signal Quality Board 3.3 Load Board 4 Preparing the Measurements 4.1 Installing Software and License 4.2 Setting Up the Network 4.3 Starting the R&S ScopeSuite 4.4 Connecting the R&S RTO 4.5 Connecting the Arbitrary Waveform Generator 4.6 Report Configuration
